disc brakes
Discussion in 'The Hokey Ass Message Board' started by THEAD, Jan 12, 2013.
  1. THEAD
    THEAD
    Have a new build installed disc brakes on my 54 ford f-100.Having trouble with the front brakes sticking or not releasing. Have the proportional valve turned all the way out. Still having problems. Any tips please.The brake pedal set up is mounted on the frame rail. The calipers came with the front end from TCI
  2. 53 COE
    53 COE
    from PNW
    Does your push rod at the pedal have a little play? What size and type master cylinder are you using?
  3. 40FordGuy
    40FordGuy
    Are you using a drum brake redidual valve ? Those are 10 psi,....Way too much for disc. Also, with a firewall master cyl, you really won't need any residual check valve.
    4TTRUK
  4. Hause
    Hause
    from Kansas
    My brother installed his calipers upside down and that caused problems for him
  5. raybug
    raybug
    its probably your brake hose my did the same thing on my 56 ford truck
  6. First step is to crack bleed screws to see if that makes it release. If it does then after they're stuck again loosen the brake line before the flex hose. That will tell you if it's the flex. Continue that procedure all the way to the master if necessary
  7. repairmanrod
    repairmanrod
    from colorado
    Can we have more information? What parts combination are you using? What are the calipers, master cylinder? Just asking there may be more to it!
    Thanks Rod
  8. 296 V8
    296 V8
    from Nor~Cal
    You didn’t do an intro … that’s why
  9. indyjps
    indyjps
