1952-59 Ford Disc brakes
Discussion in 'Off Topic Hot Rods & Customs' started by the-stig, May 5, 2011.
  1. the-stig
    the-stig
    Saw this on the main board, http://www.jalopyjournal.com/forum/showthread.php?t=586921 front disc brake conversion from Scarebird here on the hamb.
    For 52-56 Fords, about $175. Not sure what is included. Here's his website.
    http://www.scarebird.com/index.php?id=0
    Looks like it's just for the brackets. you supply the rotors and calipers, but he does tell you which ones you need. Here's an eBay link for his setup. http://cgi.ebay.com/ebaymotors/Ford...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
  2. ntxcustoms
    ntxcustoms
    from dfw
    Just bolted them on and they fit nice. Word of warning here: if you get your kit and it calls for 1990 Celebrity calipers they won't fit. Mark says instead to use 88-91 small footprint 1500 calipers and all future kits will state this. Also with this kit you'll need access to a machine shop that has a lathe with a 12" minimum swing to grind down the rotors hub if your planning to use the stock rims. On this year of kit it means that you'll have to remove a half inch of cir***ference which is a 1/4" of wall thickness. From O'reilly the parts needed cost $404....
  3. Retro Jim
    Retro Jim
    Are you using a 14" or 15" wheel ?
    Jim
  4. ntxcustoms
    ntxcustoms
    from dfw
    Stock 15" rims. I don't think 14" would fit.
  5. Joe-Racer
    Joe-Racer
    I see that you have to modify if you intend on using the stock 15" wheels, what if you use aftermarket 16" wheels? Are there other issues that would keep one from using those?
  6. ntxcustoms
    ntxcustoms
    from dfw
    Depends on what the diameter of the center hole on the 16" rims is. The rotors had to be machined down so that the stock rims would fit over them.
  7. 54RAT
    54RAT
    I used re-worked granada spindles from a company called dropem stopem (or something similar. ) They have been on the car since '98 using a dual res. master from a granada without a booster. Seem to work great and also gave me a 2' drop.
  8. ntxcustoms
    ntxcustoms
    from dfw
    Well just to let you know the scarebird way of doing things will not allow stock 15" rims. We tried a 1/4" wheel shim and it still rubs on the caliper. I was lead to believe all would be good and now $540 bucks later....
  9. old lady's mad
    old lady's mad
    can you see what needs to be done to make them work? they use granada rotors right?
  10. ntxcustoms
    ntxcustoms
    from dfw
    I think they are lincoln rotors with small footprint chevy 1500 calipers. Seems that you'll need 16s or a inch to inch and a half spacers, which I don't trust.
  11. Chalupa55
    Chalupa55
    from So-Cal
    Thanks for the heads up ntx I was going to go this route, but not anymore. I think I will go with the Drop em' and Stop em' kit now. I haven't heard anything negative about them. Yet...
  12. parklane
    parklane
    Well when **** Cohen(sp) owned it, the product and tech was excellent, but heard that he died and someone else has taken over. No info on them now.
  13. old lady's mad
    old lady's mad
    oh i think i remember the kit now. it uses slip on rotors over the original hubs right? . i think those rotors are 12 or 13inch rotors. yea you would need 16 inch wheels to clear them.
  14. ntxcustoms
    ntxcustoms
    from dfw
    11" inch rotors. The stock rims will fit over the rotors and calipers but will rub where the slots fold back and rivit the center to the rim. We are going to use 15" Wheel Vintques smoothy style rim that will still accept the stock hubcap.
  15. nascardave
    nascardave
    Hi Guys, My name is Dave and I have taken over Drop em & Stop em when **** Cohen p***ed away. I will be more that happy to help you guys with any brake problems,brake parts or brake kits. You can e mail me or call 818 572 5302
  16. 54RAT
    54RAT
    With the drop-em Stop-em kit that i bought, i am running 15x7 chrome smoothies with no issues.
  17. tbk
    tbk
    Hi, my name is Tom. I used to have a 56 victoria, but now have 65 mustang and 53 f-100. I knew **** Cohen of Drop em and stop em, and have bought brake kits from dave, who took over from ****..I think its the most complete and easiest to install with no problems.,with tech help a phone call away.
