Need a quick measurement if possible... late 70's-early 80's camaro, centerline of the spindle to the top of caliper. Need to know if i can put a set of 14" on and there will be clearance
You may also want to know the wheel mounting surface of the rotor to the outside face of the caliper. The backside of the wheel to rotor clearance is as critical as the diameter. Ray
