I need a spindle & rotor for a rear steer camero clip.It cannot be any wider than the drums.Narrow would be better.Thanks Jimmie
I don't know the space limitations you're working with, but the disc set-up is only 3/8" wider per side. Another possibility is using the newer metric rotors and calipers. Sorry I don't know just what all the numbers are for bearings but it can be done. The narrowed a-arms cut down on the turning radius. I have 1 1/2" narrowed a-arms on my cpe and can't make a u turn on a three lane road without backing up once.
