Disk brakes on a 50 poncho
Discussion in 'The Hokey Ass Message Board' started by THE CHIEF, Jan 8, 2008.
  1. THE CHIEF
    THE CHIEF
    from MIAMI
    is there a way of swapping the drums for disk brakes on stock the 49-50 poncho spindles?
  2. THE CHIEF
    THE CHIEF
    from MIAMI
  3. 53choptop
    53choptop
    I think probably the best way to upgrade your brakes if using a Scarebird kit www.scarebird.com, guys name is Mark. He sells the brackets and you buy everything else. It would probably cost about the same as if you swapped out spindles, but the scarebird route everything would come from a newer vehicle, example, I am in the process of doing my 53 olds, the calipers are from an caddy eldorado, discs from a pick-up truck, bearings from a GM auto, hoses from a Buick etc. pretty much over the counter stuff. I highly recommend Mark and his products.
  4. THE CHIEF
    THE CHIEF
    from MIAMI
