  1. mopar362000
    mopar362000
    What spindles & rotors can i use to replace the drums on a 69 camero clip.I cannot go any wider without hitting the fenders.Thanks Jimmie
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    '69-'72 A body disc brake spindles (Chevelle, LeMans/GTO, Skylark, Cutl***) will work.
  3. mopar362000
    mopar362000
    I neeed a spindle & rotor that does not set the wheel out more than the drum.Narrow would be better.Thanks jimmie
  4. 52 csb
    52 csb
    F-bodies willwork also. Have you considered using wheel with diff back spacing. Worked fer me.
