Dissolve Permatex???
Discussion in 'The Hokey Ass Message Board' started by hotrodA, Aug 6, 2013.
  1. hotrodA
    hotrodA
    I have some fairly intricately bent stainless lines that have been plugged with blue Permatex.:rolleyes:
    I can't push it through due to the bends, and don't have the stainless tubing to re-bend them.
    What will dissolve the Permatex?
    Thanks!
  2. no_fenders
    no_fenders
    Heat . use a heat gun or hot hair dryer so you don't turn the tubing blue .. 300 degrees is the magic number
  3. Gator
    Gator
    from Statham Ga
    Try soaking them in mineral spirits - I had to get some silicone mold off of a resin casting a while back and it did the trick. Took a couple days to soften it up though.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Lacquer thinner will dissolve Permatex. HRP
  5. derpr
    derpr
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yes it will, and pretty fast too.
    Don
  7. sport fury
    sport fury
    not sure this will dissolve blue permatex but i know that black permatex 2 can be disolved with rubbing alcohol.
  8. stimpy
    stimpy
    try vinager it destroys silicone ( breaks it up , its one of the ingredients in permatex
  9. sport fury
    sport fury
    heptane is used to dissolve silicone adhesive.
  10. hotrodA
    hotrodA
    Aaaaahhhh, the power of the HAMB.
    THANKS, appreciate the tips.
    Bill
  11. 325w
    325w
    Then run an old hunk of speedo cable in the dril thru it like a roto router.
  12. gatz
    gatz
    ..and smack one end to make a "spade", just a tad smaller than the tubing ID
    If the tubing ID is too small for a speedo cable, and the bends are not too severe, try some piano wire. McMaster Carr sells it. and smack the end of that too.
