Projects Distorted 1929 Model A Pickup
Discussion in 'Traditional Hot Rods' started by Bad back, Apr 2, 2024.
Tags:
  1. Bad back
    Bad back
    Hi - appreciate the dimensions of Model As has been discussed (a lot) but was after some fairly easy info. I've bought a 1929 Model A pickup that has been seriously messed about with in the roof area (a pretty poor metal frame/skin added).
    Nothing seems square now - so my questions are:
    1. Is the door side of the A pillar meant to be square to the sub frame and straight from top to bottom?
    2. What is the distance between the A and B Pillar (the gap the door fits in) and is it uniform top to bottom?
    The drivers a Pillar leans towards the rear of the car on the top half, and the distance between the A and B pillar is 725mm at the bottom but 710 at the top.
  2. alchemy
    alchemy
    The back edge of the A pillar should be straight. Can you put a long rod through all hinges at the same time?
    osage orange and Squablow like this.
  3. Bad back
    Bad back
    Thanks Alchemy - no I can't, ok on the bottom 2 but not the top one......
  4. chickenridgerods
    chickenridgerods
    from DSM, IA
    That's just some home made or hardware store hinge. I wouldn't worry about its position as you'll need to replace it.
    TBH, without seeing a wider photo we can't really tell what sort of craziness is happening to your truck cab. I'm guessing that everything from the cowl upward is home made - not just the roof.
    Squablow likes this.
