Distributor angle drives - anyone make 'em?
Discussion in 'The Hokey Ass Message Board' started by hemisteve, Sep 10, 2008.
  1. I need an offset or angle drive for the distributor for my 327 that's on the stand. I just finally found the 4 DCNF weber intake I've been looking for for years (it's an Inglese manifold) but it's missing the Inglese supplied angle drive. Does anyone else make these? The rear carb is just too close to clear a distributor in the stock vertical postion. I am also considering running a front mount distributor setup if I can't find an angle drive.
    Thanks,
    Steve
    kidcampbell71 likes this.
  2. skunx1964
    skunx1964
    even a mag wont fit back there?
  3. Nope, she's really tight - the rearmost carb hangs back almost even with the front of the distributor hole - originally Inglese supplied this setup with an offset drive but it's not with the used one that I bought and Inglese doesn't have a clue about this setup now (bought by Comp Cams and they don't even list this setup anymore)- check this out:
  4. Here's a pic of another Inglese DCNF setup with the angle drive and distributor installed - it's a shot of Steve Lykken's '32 Vicky Delivery built in the mid 80's - my apologies for the high zoot billet stuff :D
    Steve
  5. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    FWIW- Joe Hunt makes a offset base for mags.
  6. I came across an old Rod Action article this weekend that shows a Pete Jackson FRONT DRIVE as well as one the Kong made for the SBC. Was going to start a thread inquiring about them!?
  7. dave phritzie
    dave phritzie
    from us
    This is crazy, but I just found out that a friend of mine made one using weed eater parts, the angle head down where it cuts the gr***, from what he told me.
  8. Ebbsspeed
    Ebbsspeed
    Will those carbs work the other way around? That might give you a bit more clearance.
  9. I ran 40 DCNFs on a non Hamb friendly car back in the day, a '69 Fiat 124. I just thought about carbs till then! A modern high end carb will come close to the tech of those but not quite! Looks good!!
  10. From what you are saying I gather that even a crab-cap low profile MSD unit wouldn't fit.
    You might check with Joe Panek of Roto-Faze...he offered both a front-drive unit and a crab-style unit...he might well have made a rear-mount angle drive as well. http://www.roto-faze.com/ He is still in business and still building ignitions. :)
    Beyond that, my best suggestion is to use a Summers Bros. front-mount distributor.
  11. alchemy
    alchemy
    I'd bet he's figgered it out by now. (two year old thread)
  12. Unkl Ian
    Unkl Ian
    Make an offset drive, similar to what the Fuel cars run.
  13. Yep, offset drive is the plan - still looking though - this thing has just been sitting (like most of my junk) . . .
    Steve
  14. RichFox
    RichFox
    This is a duel drive. But could have just as well been an ofset drive if that was what I wanted. All it takes is a call to Boston Gear or some such some bearings and aluminum, time on a mill. If i did it you can. I once made a twin distributer drive for a Chevy
    Budget36 likes this.
  15. Unkl Ian
    Unkl Ian
  16. P Green
    P Green
    This is what you're looking for....
  17. Marty Vanin
    Marty Vanin
    jiminglese.com
    I believe he is still operating
  18. The OP has not been on in a decade, doesn't even have a profile anymore
  19. alchemy
    alchemy
    P Green is just being helpful. He doesn't realize he answered a ghost thread. Happens to a lot of newbies.
  20. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I was happy just to see a picture of one. Now I can sleep at night!
