Technical Distributor Bushing Reamer - what size?
Discussion in 'The Hokey Ass Message Board' started by Truck64, Aug 21, 2018.
  1. Truck64
    Truck64
    from Ioway
    Installed new bushing in housing. Old one loose as a goose. New distributor shaft & gear & point cam &c.
    Bushing is listed as max ID 0.4690" ; distributor shaft min dia 0.4675" ; I'd maybe take it to a shop, unless they know what they are doing they'd probably hog it out so there would be more clearance than the old setup. Depending on what they charge, too, I can pick up a reamer and who doesn't like more tools, right? Maybe a .4680" fluted reamer? The Ford shop manual calls it "burnishing" after installatiin' with tool #12132
  2. X38
    X38
    Uncanny. I was only reading this in the Ford factory manual two nights ago and wondered whether anyone still does this!
    Sorry, no answer, but my old distributors are OK in the bush dept.
    Truck64 likes this.
  3. Oldmics
    Oldmics
    Fluted reamer ???
    Doesnt that imply that it has a taper ?
    Just asking.
    Oldmics
    Truck64 likes this.
  4. Truck64
    Truck64
    from Ioway
    I'm gonna have to do this. The bushing fit on a used distributor shaft before installation, once installed though, no way no how. Tight as bark on a tree. A new shaft will not improve. Maybe a nominal size 0.4675" reamer would actually skim off juuuust enough material? Kinda sneak up on it at least. Except I don't want to keep buying reamers. Adjustable reamers?
    Most of the tools I see online when searching are called chuck reamers, for use in a lathe. I probably don't want those.
    Edit : Doh! .4685 - is 15/32nds, hand reamers are pretty inexpensive from Grainger. That would make a nominal clearance of .0012" between the shaft and bushing.
    '51 Norm and Unkl Ian like this.
  5. Truck64
    Truck64
    from Ioway
    Beats me, that's why I asked the H.A.M.B.! Good question. Think it just means there are channels.
  6. earlymopar
    earlymopar
    "Fluted" simply equates to the number of reliefs that are in front of each cutting edge. A 4-flute reamer or end mill has 4 flutes that correspond to 4 cutting edges. There are also straight and helical flutes. All of this applies to any reamer regardless of straight (no taper) or with a taper.
    - EM
    Unkl Ian, Oldmics and Truck64 like this.
  7. Texas57
    Texas57
    Early mopar has it correct. The number of flutes just tells you the number of cutting edges around the cir***ference of the cutting tool.
    Truck64 likes this.
  8. Truck64
    Truck64
    from Ioway
    I see there are adjustable reamers available, but they seem to start at 15/32", maybe that's too much to take off from the git go. I dunno.
    The original was (I think) steel oilite. Tapped it for removal and it cut easy as pie. The replacement is copper colored with an oil hole, might be a CNC aftermarket deal. The dimensions are correct, but even an old shaft won't go. New shaft is .4675", would a reamer that size be the one to use?
  9. Hnstray
    Hnstray
    from Quincy, IL
    15/16" aka 30/32nds"....almost 1 inch....not what you need . That Grainger supplied 15/32 (.4685") sounds like it may be okay..just a tad big for a new bore....but apparently within spec range
    Ray
    Truck64 likes this.
  10. Truck64
    Truck64
    from Ioway
    Thanks. Er, yeah, the dwell would be a little off after that operation! LOL, I'll edit that.
    So a spiral cut hand type reamer would be what I want? I guess the question would be what is the accepted practice for clearance in a distributor shaft. .4675" is the shaft diameter, how close to that is optimum.
  11. saltflats
    saltflats
    from Missouri
    I would get a adjustable reamer so you can sneak up on your clearance.
    Truck64 likes this.
  12. ClayMart
    ClayMart
  13. Truck64
    Truck64
    from Ioway
    That was my thought too, but it seems like size wise they start and end at 15/32", have to buy two I guess. They make a gazillion different kinds, straight cut, right hand, left hand, &c
    I'm just a simple guy trying to do a simple job. LOL
    Hnstray likes this.
  14. Truck64
    Truck64
    from Ioway
    Would that... would that work!? I don't know.
  15. vtx1800
    vtx1800
    I had some kingpins that were a little tight and used a brake cylinder hone to free them up. Worked OK.
    Truck64 likes this.
  16. Oldmics
    Oldmics
    Thanks for the education. Appreciate it !
    Oldmics
    Truck64 likes this.
  17. RMR&C
    RMR&C
    from NW Montana
    Are you replacing bushings at both ends of the housing? If so, they need to be reamed(or honed) in line with each other.
    Also, if the bushing has a parting line a straight fluted reamer won't work.
    Truck64 likes this.
  18. Truck64
    Truck64
    from Ioway
    This is an older Ford/Autolite distributor. Only one bushing on those.
    I think maybe sneak up on it with a dingle ball hone will actually work. That's why you guys make the big bucks.
    RMR&C likes this.
  19. Find a manual and see what your clearance wants too be. Measure your shaft (actually measure it don't take the shaft size as advertised for granted) and buy a reamer the proper size according to shaft size and clearance.
    Yes a fluted reamer is a good idea. I like mine to be align bored so a reamer that has a snout to reach the top bushing is my personal preference.
    Truck64 likes this.
  20. Truck64
    Truck64
    from Ioway
    The shaft actually measures .4675" with a mic on an unused portion, and that is the minimum accepted size in the book, but finding it difficult to determine accepted running clearance between the two. I can see daylight in the mic on the worn part of the shaft, probably .001" or .002" wear, not much but enough to ****** the dwell when bush wear is added in too. The new distributor shaft will be here Friday maybe. It will measure exactly .4675" or near enough I expect.
    The manual pretty much only talks about endplay. I have written down max ID allowed for the bush is .4690" but I can't remember where I found it. It's not in the shop manual as such.
  21. saltflats
    saltflats
    from Missouri
    I have one you could barrow.
    Truck64 likes this.
  22. ClayMart
    ClayMart
    I don't see why not for no more material than you'll probably need to remove. Just sneak up on it a little at a time and make sure to flush out any abrasive residue before you put it all back together. ;)
    Truck64 likes this.
  23. Unkl Ian
    Unkl Ian
    Do it.
    Truck64 and Hnstray like this.
  24. dreracecar
    dreracecar
    from so-cal
    Spiral cut is for those cases of a keyway or split in the hole to be reamed where as the straight cut would get hung up in the slot
    Truck64, RMR&C and Unkl Ian like this.
  25. dirt t
    dirt t
    I'm not a machinist , but could you chuck your distributor up in a lathe and bore it to fit?
    Truck64 likes this.
  26. Texas57
    Texas57
    Just for the record, a reamer will flex enough to follow the location an existing hole, meaning it will not ream inline two holes that are not inline to begin with. Usually .001-.002 max removal. To straighten or accuratly locate a hole it must be single point bored first, then ream if wanted. (21 years machine shop, including lots of space shuttle work)
    Truck64 and RMR&C like this.
  27. earlymopar
    earlymopar
    Absolutely true, contrary to what many believe.
    - EM
    Truck64 likes this.
  28. sunbeam
    sunbeam
    Take a 1/4'' rod slot the end of it with a saw stick co**** emery cloth in it and wrap it until it's close to shaft size and use a drill
  29. Hnstray
    Hnstray
    from Quincy, IL
    Guys, talking about using homes in this bushing......bear in mind it’s inner diameter is less than half of an inch.......there may be hones that small, but none of the brake cylinder hones I have, or have had, have ever been that small in diameter.
    I do like the idea of the slotted metal rod (or maybe a wood dowel) with sand paper ....
    Ray
    ClayMart and Truck64 like this.
  30. Truck64
    Truck64
    from Ioway
    I thought that's what the Dishwasher is for.
    Hnstray likes this.
