distributor is too big
Discussion in 'The Hokey Ass Message Board' started by hodge!, Jan 1, 2009.
  1. My friends car eats bronze cam gears about every 8000-10000km. A high volume/high pressure oil pump puts a bunch of load on the gear.
  2. Shifty Shifterton
    Shifty Shifterton
    That's why there's a big step on the distributor, same size as the gasket. If the gasket don't fall thru, that hole's the right size.
    If you put a set of meat-hands on a distributor, you can flex it back n forth that much. If it's got bad bushings and excessive end play the problem gets worse because now you're only wobbling/flexing the housing without the tight-fit support of the shaft.
    If the distributor truly flops around, the problem ain't the intake hole.
  3. sdluck
    sdluck
    Did you check if the dist gear is positioned right on the cam gear?
  4. OldBuzzard
    OldBuzzard
    distributor is too big???
    In any case, If the distributor is down where it belongs it can't move sideways much at all. The pilot bore in the block is too close a fit. If the oil pump drive tang is engaged with the dist. seated on the manifold, something is seriously wrong with some diameters there.
  5. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    I tore the distributor down to clean it up and inspect the parts/bushings to ensure no catastrophic scenarios. :)
    The dist gear is held on by a spring pin, and between it and the housing was 1 washer/bushing. There was very little play, which was within specifications from my research.
    What I have not done is turn the cam/crank to see if the distributor can seat better. It feels like the distributor is sitting a hair above the machined surface w/ the gasket in place. Maybe im not getting a good install w/ the gears being off by a small amount limiting proper meshing.
  6. dave lewis
    dave lewis
    from Nampa ID
    chop, are you online ?? Check your pms...
  7. Shifty Shifterton
    Shifty Shifterton
    dude you're not lining up with the oil pump drive. Reach down in with a long screwdriver and turn it so it aligns with the rotor
  8. 53sled
    53sled
    from KCMO
    stock chevy distributor from a 90 truck 350, bronze drive gear.
    Myth busted.
  9. 39 All Ford
    39 All Ford
    from Benton AR
    or - just bump the engine around until the distributor drops... I do it that way cause I am lazy...
  10. Shifty Shifterton
    Shifty Shifterton
    That is a great technique, if you're 100% confident it's in the right tooth.
  11. 39 All Ford
    39 All Ford
    from Benton AR
    I engage the gear in the right place and then bump the engine around until the dist drops the last 1/4" or 1/2"...
    This has always worked for me on Chevys...
