Technical Distributor Machine.
Discussion in 'The Hokey Ass Message Board' started by 1Nimrod, Jan 24, 2026 at 11:57 AM.
  1. 1Nimrod
    1Nimrod
    Any members that own a Distributor Machine that knows about Mallory Dual Point Distributor with Vacuum Advance and willing to set up my Distributors. What's the going rate for this type of labor?
    Thank you for any help...
    Dustin
    (1Nimrod)
    dana barlow likes this.
  2. Chiefrider
    Chiefrider
    from Lower 48
    Shouldn't make any difference because it a Mallory, unless it's something with oddball mounting like a flathead Ford, which take a special adapter to hook it up. The mounting and hookups on the machines are pretty versatile, including a vacuum pump and meter
    1Nimrod and dana barlow like this.
  3. lostn51
    lostn51
    from Tennessee
    Moriarity owns one he should have an idea about the cost and labor involved
    1Nimrod likes this.
  4. 1Nimrod
    1Nimrod
    Thank you, just want to get my Distributor set up correctly, it's for a Chevy 1965 327.
    I'm still hoping a long standing HAMB member has a Distributor Machine or knows of a reputable shop that works with Distributors and Ignition regularly.
    Dustin
    (1Nimrod)
  5. lostone
    lostone
    from kansas
    You can do the same thing in a running engine with an adjustable timing light....
  6. 1Nimrod
    1Nimrod
    I already talked to him, thank you.
    Dustin
  7. 1Nimrod
    1Nimrod
    I have an old Snap-On timing light thats adjustable, thank you as well my friend.
    Dustin
    tractorguy likes this.
  8. 57 Fargo
    57 Fargo
    Shipping would be a ***** but I can do it as well
    1Nimrod likes this.
  9. G-son
    G-son
    from Sweden
    You could use a timing light, a good tachometer and something to get varying amounts of vacuum to figure out what rpm it begins to advance, what rpm it's at max, how much it changed between the two, what vacuum it begins to advance and at what vacuum it's at max, how much it changed, and then adjust everything to what your engine needs... but it seems far more convenient to do it on a distributor machine.
    1Nimrod likes this.
  10. 1Nimrod
    1Nimrod
    Oh boy your across the border, yes a bit costly but thank you for offering 57 Fargo I appreciate it very much.
    Dustin
  11. 1Nimrod
    1Nimrod
    Yep exactly my thinking as well.
    Thank you very much.
    Dustin
    G-son likes this.
  12. Adriatic Machine
    Adriatic Machine
    I don’t know this guy personally but I follow his page and he seems really knowledgeable and easy to work with.
    1Nimrod likes this.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    man I would have a tough time trusting a guy to work on my stuff that can't spell "carburetor"!!!!
    Paul, Ziggster and saltflats like this.
  14. 1Nimrod
    1Nimrod
    Thank you AM my friend.
    Do you know were he is located?
    I appreciate your help, thank you again friend.
    Dustin
  15. 19Eddy30
    19Eddy30
    from VA
    Look into local Engine builder shop's..
    Most Performance""Engine Builders"" that have been doing for 20 plus years have Distributor machine,
    @ least in my Area
    1Nimrod likes this.
  16. 1Nimrod
    1Nimrod
    Yes I've been checking in my Black Book all the Machine Shops I've worked with in the past so far no luck. Thank you for your suggestion it's much appreciated my friend.
    Dustin
  17. 19Eddy30
    19Eddy30
    from VA
    Much easier with a machine,
    But can be done also on a bench
    12v batt
    Electric motor
    Vacuum cleaner belt
    Tac
    Light
    Vac gauge
    Vacuum
    Wires
    Distributor & ext .
    Or
    if easy to work on a running engine
    Pulling distributor at least three times with notes to dial in .
    1Nimrod likes this.
  18. 19Eddy30
    19Eddy30
    from VA
    Not Machine Shop!!!
    Performance engine builders with Dyno
    & with Machine Capability
    1Nimrod likes this.
  19. 1Nimrod
    1Nimrod
    I only worked with two Performance Engine Builders in the past both closed now, both owners p***ed away.
    I'll keep looking for Performance Engine Builders in different Counties around me. Thank you I didn't understand what you said the first time. I appreciate your help my friend.
    Dustin
  20. Adriatic Machine
    Adriatic Machine
    West Bloomfield NY
    1Nimrod likes this.
  21. Ziggster
    Ziggster
    Like @57 Fargo, I could probably look at it with my Allen Syncrograph, but I’m also on the other side of the border. There is a guy “Charlie NY” on the BARN that rebuilds carbs and distributors I believe.
    1Nimrod and 57 Fargo like this.
  22. 1Nimrod
    1Nimrod
    Thank you again AM for your help it's much appreciated my friend.
    Dustin
    Adriatic Machine likes this.
  23. 1Nimrod
    1Nimrod
    Not sure what the "BARN" is ?
    Dustin
  24. 19Eddy30
    19Eddy30
    from VA
    Sister site
    The Ford Barn . Com
    Ziggster and 1Nimrod like this.
  25. Ziggster
    Ziggster
    1Nimrod likes this.
  26. Chiefrider
    Chiefrider
    from Lower 48
    Once you use a good machine, you'll find that it is much easier and way more accurate than trying to do it in the vehicle with a timing light. One of my machines has an "Ignition Simulator" on it, which, in addition to a distributor, has a ballast resistor, coil, cap and wires, and 8 plugs- training device that's fun to watch
    1Nimrod likes this.
  27. 1Nimrod
    1Nimrod
  28. 1Nimrod
    1Nimrod
    I appreciate everyone's help Thank Y'all...
    Dustin
  29. Adriatic Machine
    Adriatic Machine
    And yet still the most viable suggestion in the thread so far… other than the guy who got banned from multiple sites.
  30. 1Nimrod
    1Nimrod
    Sounds like the Sun Distributor Machine we had back in High School.
    Dustin
