While recurving my Motorcraft dizzy, the retainer clip for the advance plate took flight. This is about 1/4” diameter with two vertical legs. Where can these be purchased? Thanks ken
Sounds like your talking about one made of spring wire? I have in the p***ed in a pinch,as a temp way of making things work,I used safety wire an looped it around with one twist{wire needs to be about same size as clip you lost.
Sounds like what we called a " hairpin " clip. You might see if you can find one through where they have miscellaneous carburetor parts.
