Technical Distributor Rotor / Cap causing backfire?
Discussion in 'The Hokey Ass Message Board' started by David Gersic, May 22, 2023.
  1. David Gersic
    David Gersic
    from DeKalb, IL
    Brother In Law
  2. David Gersic
    David Gersic
    from DeKalb, IL
    I did try the pump cam moving from #1 to #2 hole. That didn’t move much, and didn’t help anything, so I put it back.
    I have t tried other cams. I know they exist.
    PCV is over by #8. Having trouble imagining how PCV would **** anything out of the cylinder directly. #8 was only 135 PSI a couple years ago, so it’s probably just wear. Not too unexpected for a 1974 long block that I don’t think has ever been apart.
  3. David Gersic
    David Gersic
    from DeKalb, IL
    I haven’t changed wires yet, so that’s still a possibility.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    If you're dropping to 4.5-5" hg @ light throttle opening I would think you'd want a PV that opens @ 3.5 . Its the seemingly low vacuum @ light throttle that bothers me ?, that " seems " more like a worn out motor / heavy vehicle scenario ?
    427 sleeper likes this.
  5. jaw22w
    jaw22w
    from Indiana
    You have 28 degrees of advance at idle? With no vacuum? How does it start? Does it buck the starter? I would think the idle timing should be in the neighborhood of 12-16 degrees with no vacuum advance. It looks like the mechanical advance is coming in too soon.
    To me, the cruise ratio looks pretty good, if maybe just a little lean. WFO looks good at 12-13:1. Idle at 17:1 seems way to lean to me. How far out are your idle mixture screws? The engine runs on the idle circuit until maybe 2000 rpm, when it moves on to the main jets. If the idle circuit is lean, then you are probably running lean when the problem occurs. Idle flow is controlled by the idle feed restrictors in the metering blocks or plates. I don't know if your carb has changeable jets there, but you might try richening up those IFR's.
    I have been playing with my AFR gauge for a couple of years now. I added a vacuum gauge right next to the AFR gauge. That helps understand what is going on. You can see when the PV is activating.
    Something you need to remember is that with most installations there is only one O2 sensor, so you are only getting an AVERAGE of the four cylinders in one bank, half of the engine So that afr gauge is not necessarily the last word.
    David Gersic likes this.
  6. David Gersic
    David Gersic
    from DeKalb, IL
    Cranks and starts fine. No bucking or kickback. The cam has enough overlap that this is where I ended up on the static advance. A more appropriate cam would probably work better with less static advance.
    With the medium springs, I’m not getting a lot of mechanical advance. Going to the light springs for more got me in to detonation territory. Went back to medium.
    Idle mixture was tuned for best vacuum at idle. I don’t know how many turns that is, exactly.
    Currently have my vacuum gauge next to my AFR gauge. At 5”, the 6.5 PV is definitely in play here.
    Good point on the O2. I’m reading the drivers side bank and ***uming that the p***enger side is the same. Not necessarily true. And it’s not per cylinder.
  7. David Gersic
    David Gersic
    from DeKalb, IL
    The bottom end is probably somewhat worn. A 74 long block that I don’t think has ever been apart. But the cam has enough overlap for not making a lot of vacuum.
    Not especially heavy, a 37 Chevy sedan.
    Lower opening PV is an idea. I was thinking about trying a 4.5 to see if that does anything helpful. Conventional wisdom is half of idle vacuum, which puts me at 7 (6.5), and that more fuel / rich is better than not enough / lean to keep from burning pistons.
    GlassThamesDoug likes this.
  8. 2OLD2FAST
    2OLD2FAST
    from illinois
    You keep referring to the can , could you post the specs ?
    28° @ idle is a bunch !
  9. David Gersic
    David Gersic
    from DeKalb, IL
    Crane Cams Fireball II 290H
    Part #114802
    Lift:
    Intake @cam: 3027 @Valve: 454
    Exhaust @cam: 3027 @Valve: 454
    Rocker Arm Ratio: 1.5
    Cam Timing @.001 Tappet Lift:
    Intake Opens: 35 BTDC Closes: 75 ABDC
    Exhaust Opens: 75 BBDC Closes: 35 ATDC
    Advertised Duration: 290
    Spring Requirements
    Part #99848
    Closed: 105 lbs. @ 1.700 (1 45/64)
    Open: 265 lbs. @ 1.280
    Cam Timing @.050 Tappet Lift:
    Intake Opens: 3 BTDC Closes: 33 ABDC Max Lift: 105 ATDC Duration: 216
    Exhaust Opens: 43 BBDC Closes: (7) ATDC Max Lift: 115 BTDC Duration: 216
    Recommended RPM Range
    Minimum: 1800
    Maximum: 4400
    Valve Float: 6500
  10. David Gersic
    David Gersic
    from DeKalb, IL
  11. David Gersic
    David Gersic
    from DeKalb, IL
    I’ve been out of town on a road trip. Left northern Illinois last Friday. Two days to get to Atlanta via secondary roads, including a trip through Tail of the Dragon. Five days of Power Tour from Atlanta to Bristol. Then two days to get home via Cherohala Skyway and secondary roads.
    Not a single backfire from the engine.
    So I think I fixed it. I don’t understand the actual failure, but I changed one thing (power valve) and it got better. So it must be the PV.
    I compared the opening of the old PV:
    to the new PV:
    The PV feeds gas to a pair of (drilled) restrictors, so I don’t know if this difference matters. Or if there is some other failure of the PV that I can’t see or measure.
  12. pprather
    pprather
    I would think that length road trip would be an adequate shakedown.
    Carry on!
    GlassThamesDoug and David Gersic like this.
  13. ekimneirbo
    ekimneirbo
    Congrats David.........:p
  14. s55mercury66
    s55mercury66
    from SW Wyoming
    This is a good read, and I remember the ignition timing thread. That thread helped convince a few of my friends that the engine will tell you want it wants for timing, and the specs it likes are the specs one should use.
