ditching my 6
Discussion in 'The Hokey Ass Message Board' started by Tricky53, Apr 11, 2012.
  1. Tricky53
    Tricky53
    from Bend, OR
    So I've decided to ditch the worn out 235 in my '53 and put in a 350. I found a great running 350 out of a '78 suburban. I've also found a newly rebuilt powerglide trans to put behind it. I've never ran a powerglide before and have a few questions. The car is going to be my daily driver. Most driving will be around town with the occasional trip to Portland (about 180 miles). The 350 will be basically stock with the exception of a new carb and intake (probably edelbrock). I haven't found a rear end for the car yet and am open to any and all suggestions for something that will be the right width and gear ratio for my set up. What should I look for?
  2. deto
    deto
    53 what? camaro 10 bolt
  3. yetiskustoms
    yetiskustoms
    Its a 53 chevy belair. I have found that camaro rearends and s10 4x4 rears work well. Good luck tricky53. Maybe i can help on that
  4. 73super
    73super
    I did a '57 Chev (4 door).. but the ratio isn't a good one for me. I'd go with the S10 (4x4). I was told it was geared for highway driving, but I have a 350 and a TH350 and I sure could use an O.D in that thing. Great for around town tho'.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    The racers love Power Glides but in your case I would sell the 'Glide and use a 200R4 from 1988-93 these are overdrive and non-computer and being narrower will be an EZ and better fit for your swap.
  6. deto
    deto
    95 s10 4x4 axle fits and has 342s with a posi
  7. 270ci
    270ci
    I used the rear out of a 55. Width was fine and with a pair of Posies springs, it was a bolt in. Mine has a 3.55 ratio which works great with my 200-4R ******. Not absolutely sure, but I think 55-57 Chevy rears are the same.
  8. Tricky53
    Tricky53
    from Bend, OR
    Thanks for the responses.Well, looks like I'll use an S10 out of a 4x4. Thanks yetiskustoms, I need all the help I can get.
  9. toms37gmc
    toms37gmc
    Not sure on the rear end, but agree with JeffB2, ditch the power glide for a TH350 or 200R4. Especially if you are going to be doing a lot of around town (stop and go) driving. Dumping the PG for a TH350 was the best thing I ever did on my 37GMC.
  10. Tricky53
    Tricky53
    from Bend, OR
    I picked up the PG that has been completely rebuilt for the cost of a core trans. I'm gonna use it for now so I can at least be driving my car for the summer. I'm on the lookout for a th350 that I can rebuild and swap into the car later. The cars has been off the road for about 10 months, I've got to get her back on the road ASAP! My goal is in time to drive up to the Rose City Roundup!
  11. yetiskustoms
    yetiskustoms
    rode city roundup here we come!:D
  12. derbydad276
    derbydad276
    what he said
    unless your racing skip the glide
    gear ratios for s 10 4x4 check the glove box for option codes
    GU4 is a 3.08 1983to 1997
    GU6 is a 3.42
    GT4 is a 3.73
    89's had a HO4 that is a 4.11
    if its a zr2 its a 81/2 ring gear 3.73 ratio
    w/o zr2 its a 3.42
  13. Tricky53
    Tricky53
    from Bend, OR
    Can't believe it, scored a 235 and 3 speed out of a '55 chevy car so now the powerglide is for sale. I think one of the guys in my club wants it so....I'm not ditching my 6!
  14. My 54 has a rear out of a early 70s, Nova or the Pontiac equivalent. Note that the stock 53 rear has offset spring centerbolt holes.
  15. Tricky53
    Tricky53
    from Bend, OR
    Thanks, I ended up getting an S10 4x4 rear end that I'm gonna use for it. Everyone says its a good rear end that will be the correct width and will well enough.
  16. yetiskustoms
    yetiskustoms
    how far off center are the axle/ leaf pins? is it something that can be redrilled in the pad to move the axle forward??
    ( s10 rear axle on stock 53 springs)
