Technical Dixco tach wiring?
Discussion in 'The Hokey Ass Message Board' started by Paul, Jan 16, 2025.
  1. Paul
    Paul
    Editor
    looking for a wiring diagram for my Dixco Model 77 tachometer.
    it has two white with red stripe wires, a smaller gauge white with black and red stripes, and the 8 and a 6 cyl posts..
    I can't seem to find anything on the model 77 or this wire configuration
    photo with cup removed:
  2. squirrel
    can you remove that inner cup, and see if perhaps the wires had been replaced? Wires like that were typically used inside complicated electronic equipment....and the Dixco stuff all suggests black, white, and green.
    bchctybob, Paul and 41 GMC K-18 like this.
  3. Paul
    Paul
    Editor
    I'll do that
  4. RodStRace
    RodStRace
    Having all three have the same color and trace (the Black is also over White/Red) makes me guess either dixco used the same wire and added the additional color with the other 2 wiped off over the years or as @squirrel mentions, someone rewired. Both of the others seem to have portions that have double trace of Red. Curious.
    Paul likes this.
  5. RodStRace
    RodStRace
    Paul likes this.
  6. tubman
    tubman
    Standard tachometer wiring is usually :
    Red - Power
    Black - Ground
    White - Light
    Green - Tach Signal
    If not, "Ground" and "Light" should be be able to be determined with a little looking; the other two might be a little harder, but considering their use, you may be able to figure it out.
    Paul likes this.
  7. squirrel
    Dixco wiring had Black as Ground only when it was Positive Ground car. With normal Negative Ground wiring, White was ground, Black was ignition power.
    like lots of other things, ie. houses, trailer lights, etc.
    warbird1, bchctybob and Paul like this.
  8. Paul
    Paul
    Editor
    yup, a bit of a mess inside..
    hopefully I can just replace the odd wires and clean up their soldered connections.
    to be continued
    PXL_20250117_012619745.jpg PXL_20250117_012629891.jpg PXL_20250117_012655546.jpg PXL_20250117_012716649.jpg PXL_20250117_012908378.jpg
  9. tubman
    tubman
    With looks of that, I wonder if it even works anymore. Looks like "Bubba" was in there first.
    Good luck with it.
    squirrel and Paul like this.
  10. RodStRace
    RodStRace
    That old thread had some inside pics, hope it helps.
    EDIT: like this
    bchctybob, loudbang and Paul like this.
  11. Paul
    Paul
    Editor
    I hear ya, it may end up being a parts tach, but I was hoping to use it or maybe find another Dixco,
    they were made on Vashon Island WA, where I spent most of my formative years.
    warbird1 and bchctybob like this.
  12. Paul
    Paul
    Editor
    not finding wiring diagram for the model 77 yet
    but here is a picture of the back of one I just ordered,
    used, untested but looks complete,
    hopefully between the two I can make one.
    looks like
    big black
    big white
    medium green
    small black
    bchctybob likes this.
  13. squirrel
    I think that's a newer model, might be hard to figure out what was what on Paul's old tach.
  14. RodStRace
    RodStRace
  15. Paul
    Paul
    Editor
    fwiw the clock in my dash has the spring wind mechanism original to it.
    'gives me something to do while the engine warms.
    all the way to the right of the dash
  16. Paul
    Paul
    Editor
    follow up on my Dixco tach
    I was lucky enough to find another matching #77 that was good internally but not so nice on the outside.
    mine was a mess inside but cosmetically the outside was good.
    simple swap made two tachs
    one good inside and out
    and one not.
    when wired as suggested above,
    ie:
    green negative post of coil
    black positive post coil
    white ground
    it seems to be working properly
    I have yet to attach another for comparison
    but it looks good.
    here connected to running engine
    edit:
    these tachs were made on Vashon Island WA
    the picture above of the dash was taken on Vashon last summer
    rod1, loudbang, squirrel and 4 others like this.
  17. RodStRace
    RodStRace
    Glad you were able to get what you wanted. Seems like it won't match, but will spark conversation and the local connection (even printed on the face) makes it work!
  18. Paul
    Paul
    Editor
    the Dixco tach will go on the engine test stand's control panel.
    it will get a couple other vintage gauges, a few toggles, ****ons and bows, a keyed switch and a throttle lever.
    it will match the ensemble just fine.
    for what it's worth
    I did swap the tach in the dash picture out.
    it was replaced with a mechanical tach when I put the magneto in.
    rod1, loudbang, kadillackid and 2 others like this.
