DIY Spray On Chrome
Discussion in 'The Hokey Ass Message Board' started by nicamarvin, Feb 24, 2012.
  1. cromarte
    cromarte
    from argentina
    Hello everyone, I'm new to this forum .... I'm from Argentina know understand my bad English .... I am developing as many of you spray on chrome sitema ... someone will step the mirror is not so good when you are in the sun? at a certain angle?
  2. cromarte
    cromarte
    from argentina
    hello friend... very good job! clear coat is tinted purple? or is transparent and does not yellow? which brand of product you use?
  3. sudzhis
    sudzhis
    from Latvia
    Its tinted purple! Brand is Tikurila
  4. cromarte
    cromarte
    from argentina
    the mix did you? how much and what measures did you use?
  5. cromarte
    cromarte
    from argentina
    I tried with many weapons .... hand guns, air gun, spray ... we are using air guns, watch the video http://www.youtube.com/watch?v=NTdFekw4gns&feature=youtu.be we are manufacturing our own chemicals, I would like to share with you some of my formula little problems .. to operate the air gun used at very low pressure + - 1-5 psi
  6. cromarte
    cromarte
    from argentina
  7. sudzhis
    sudzhis
    from Latvia
    Yes, I have my own formula! Check PM!
  8. cromarte
    cromarte
    from argentina
    what is your formula of tin that you are using?
  9. cromarte
    cromarte
    from argentina
  10. sudzhis
    sudzhis
    from Latvia
    Looks a little bit yellow! Or maybe images is not so good!
  11. cromarte
    cromarte
    from argentina
    as said nicamrvin, silver has a small yellow component that differentiates it from the actual chrome, the picture is not tinted varnish
  12. sudzhis
    sudzhis
    from Latvia
    And Where is problem than? Tinted clear coat will give u right color. Or i missing something?
  13. nicamarvin
    nicamarvin
    from nicaragua
    this is correct. for production like eviroment I would stick with Alsa chrome tinted clear coat, if not on an production or business enviroment you can try and mix your own tinted clear coat
    Alsa tinted clear coat
    <iframe width="420" height="315" src="http://www.youtube.com/embed/Y0YP1zcShew" frameborder="0" allowfullscreen></iframe>
    do you want to know how good is your tinted clear? or fine tune it? well you can do it by silvering silver s****s and trying them out. first you need to prep the s**** for the silvering then silver the spons and clear coat them with none tinted clear coat wait 1 or 2 days for the clear to fully cure. then test how good is your mix with one or 2 s****s, you can adjust the mix if its too yellow or too violet. always keep a real chorme piece at hand so you can cross check to see it..
    here the silvered plastic s****s(no clear coat it)
    <iframe width="420" height="315" src="http://www.youtube.com/embed/zX6ZDp7oODY" frameborder="0" allowfullscreen></iframe>
    tinted clear coat vs none tinted clear coat
    <iframe width="420" height="315" src="http://www.youtube.com/embed/MqsJ9jqVCx0" frameborder="0" allowfullscreen></iframe>
    Here compared to real chrome
    <iframe width="420" height="315" src="http://www.youtube.com/embed/Vh0iVlcQeRw" frameborder="0" allowfullscreen></iframe>
  14. cromarte
    cromarte
    from argentina
    I use polyurethane concentrated, violet and blue, but violet .. and I will upload some pictures .. someone tells me how to upload pictures?
  15. sudzhis
    sudzhis
    from Latvia
    cromarte upload pictures in some web server like http://postimage.org/
    than just paste images URL in the middle [​IMG]
  16. sudzhis
    sudzhis
    from Latvia
    i had a very strange problem today! My silver liquids didnt work good! silver chemicals work slowly, not so good as always and after silvering on surface was blue areas, like blue water drops! I tryed to get in balance my spray gun, but nothing good! I decided that if i spray on surface wet coat of silver for start, and then silver+reducer then all works +/- good!
    Maybe problem was with T`, because in my country winter is back F*CK and outside is -7-14`C and inside was not more than 17` I think!
  17. cromarte
    cromarte
    from argentina
    that reducing use? the glucose and fructose desxtrosa decompose .... store in refrigerator .. formaldehyde have an expiration date ... Sodium hydroxide also has its time
  18. cromarte
    cromarte
    from argentina
  19. hawaiiboy
    hawaiiboy
    from Hawaii
    Hi Everyone,
    Wow all of you have created some really great pieces. I need some help. I have been trying to overcome a yellowing problem when I spray the clear coat. I am using Shermin Williams urethane clear and as soon as I spray it on you get the yellow tint. I have also tried to tint it purple and blue with no luck. It still has a yellow tint. If I spray enough clear on the piece to remove the yellow then the piece looks to dark like a black chrome. Any suggestions would be greatly appriciated.
    This is such a great forum, I have learned alot from all of you.
    Thanks
  20. sudzhis
    sudzhis
    from Latvia
    Before clear coat silvered part is Chrystal clear mirror or it is some yellow shadows?
    Do Your tint is strong enough?
  21. nicamarvin
    nicamarvin
    from nicaragua
    Nice Job Cromarte. very good job
  22. nicamarvin
    nicamarvin
    from nicaragua
    I would like to point out that Cromarte has the process right, he only needs to work on his chrome tinted clear coat thats all...
  23. sudzhis
    sudzhis
    from Latvia
    Hi! Yes nice job! What can I say that spray clear coat on s****s is easy job! There is almost impossible to do it wrong! Other thing is spray larger item! This is different story....!
  24. cromarte
    cromarte
    from argentina
    you're right, there are more problems large pieces either sensitizer or reducer, etc. and I will upload photo of some purple dye pieces.
  25. cromarte
    cromarte
    from argentina
    6 using 2 drops of violet and blue in 100 cc of varnish ... You have to apply the right amount if you spend will be put viole
  26. cromarte
    cromarte
    from argentina
    I had a problem, when we apply the silver has to be very clear white and not a dark silver, but to our eyes look good, to apply the clear coat will darken much.
    the details we do not see with the eyes of the varnish are then
  27. sudzhis
    sudzhis
    from Latvia
    Ou Yes , U are right! Try this trick! Take some gl*** piece l, clean it and silver it! Blow of the water and look on sun or lamp! If silver layer looks ok, this mean that problem is on silver! If u will se some darker places or something like dark water drops, than problem is under! Maybe your problem is on silver! Try to wash and blow off the water 2-3 times
  28. nicamarvin
    nicamarvin
    from nicaragua
    I beg to differ, I had a very hard time doing my first s****s, I learn alot by doing them and believe me, my first 10 s****s were very bad,
  29. nicamarvin
    nicamarvin
    from nicaragua
    I have pointed this out this issue in this thread many times,
    you sea a nice mirror but when you clear coat it it turn very dark, the reason? not enough silver.. check my posts
  30. nicamarvin
    nicamarvin
    from nicaragua
    the issue is not enough silver was applied, I have had this issues before
