DIY Spray On Chrome
Discussion in 'The Hokey Ass Message Board' started by nicamarvin, Feb 24, 2012.
  1. sudzhis
    sudzhis
    from Latvia
    Good luck with Your kid NIcaMarvin!
  2. brian55lvr
    brian55lvr
    from ma
    good news! :)
  3. M5StudeGuy
    M5StudeGuy
    from Atlanta
    Glad to hear it NicaMarvin...
    NOTHING like having kids...
    ENJOY, he'll grow up WAY too soon...
  4. nicamarvin
    nicamarvin
    from nicaragua
    thank guys...
    Hey Chromearte any news? or update from Sud?
  5. cromarte
    cromarte
    from argentina
  6. sudzhis
    sudzhis
    from Latvia
    Cromsarte- nice elephant! U must to send it to India, they will like it :)
    when u add photo please make smaller size of imsges, because these big one broke forum! :)
  7. sudzhis
    sudzhis
    from Latvia
    Nicamarvin its good,. that all is ok with Your kid :) Im testing millions of top costs and clear coats for adhesion!
    I find some russian forum, this forum is for money but there is lot of interesting information!
  8. cromarte
    cromarte
    from argentina
    sorry some day I will learn to use this forum: D. ... I know that forum you name it .... hope you get some information
  9. nicamarvin
    nicamarvin
    from nicaragua
    Wow thats some nice work you did cromarte... nice to see you are doing well..
  10. sudzhis
    sudzhis
    from Latvia
    Cromarte- do u know Russian language? If u dont, google translate dont help there! :) Send to PM with forum u know! Thanks
  11. sudzhis
    sudzhis
    from Latvia
  12. cromarte
    cromarte
    from argentina
    hello people! I'm having trouble with the dye chrome effect .... I'm using varnish 50cc, 25cc hardener, and 40% thinner ... 3 drops blue and 1 purple ... tone was the best achieved, but it is as one would expect .... NICA you provide using you? someone give me information to keep trying
  13. cromarte
    cromarte
    from argentina
    do not speak Russian ... but I will use google ... have something interesting :p?
  14. sudzhis
    sudzhis
    from Latvia
    Be careful about thinner ;) Many masters newer use thinner for first coat! Thinner can make LOT of problems! I do not use it too!
  15. sudzhis
    sudzhis
    from Latvia
    In this site is only images! Forum is in different place, but u will dont understand nothing there with google translate because there is dzhiburish not Russian :)
  16. cromarte
    cromarte
    from argentina
    the varnish I use if or whether to dilute 40% with thinner :(.
    Today varnished, metalizamos tomorrow, and tomorrow we apply the topcoat, I'll probabar with 4 drops of blue, 1 drop of violet
  17. sudzhis
    sudzhis
    from Latvia
    U will get next problem- if too much blue- part will look green!
  18. nicamarvin
    nicamarvin
    from nicaragua
    and Thats why the Correct color is "Violet" not blue... Violet will negate the yellow..
    here this I how I test for a color that will negate the yellow. I took a bronze or br*** Owl I Polishe it to a mirror look, then mix my violet tinted clear coat. now keep in mind the owl is alot more yellow than our spray on chrome silver. so the Violet has to be alot stronger for it...
    http://www.youtube.com/watch?v=sfPnUDrdJ0A
  19. cromarte
    cromarte
    from argentina
    are you using only violet on the clear coat? how do you ask the colours on the shop? some code? what type of violet?
  20. nicamarvin
    nicamarvin
    from nicaragua
    no I just mixed blue with magenta... sorry
  21. cromarte
    cromarte
    from argentina
    ratios which are blue and magenta?
  22. nicamarvin
    nicamarvin
    from nicaragua
    that you would have to test yourself buddy, since we use different type of paints
  23. sudzhis
    sudzhis
    from Latvia
    Hi for all! Still testing lot of clear and top coats! Fighting with adhesion! There is loooot of problems and trust me, polyurethane clear coat/top coat is not the answer!
    1. Actually there is no good any of usually paint- acrylic, polyurethane, acrylic/urethane! All of them is bad for this thing!
    2. Yes, adhesion is better with blue fire!
    3. Ceramic clear coats is better for ON silver coating!
    4. Companies as cosmichrome, fantachrome is producing special paints! special top coat for silver! Adhesion is really good! Secret is in adhesion chemicals in top coat- as epoxy etc. This top coat is easy to wet even with weak sensitizer like from AG.
    5. For clear coats thats same special adhesion adds to it!
    with usual clear and top coat this spray on chrome system is good for room use only! But with right paints it is durable as usual paint!
    dohh,,,,,,,its so so complicated!
  24. naliorf
    naliorf
    hi..why so complicated sir? you mean this is not really working? spray on chrome is not good?
  25. naliorf
    naliorf
    hello marvin. just want to ask if you have the same problem with sudzhis? problem with adhesion? :confused:
  26. cromarte
    cromarte
    from argentina
    is true that says sudzhis ... the issue of adherence is an important factor ... we must try many varnishes .. I have an excellent adhesion of the silver on the base coat, but poor adhesion of the topcoat
  27. sudzhis
    sudzhis
    from Latvia
    No, its working! But main question is quality of base/top coat and adhesion to silver for both sides!
    Usual clear coat/top coat newer will work for spray on chrome! It will work but not stable, not trust-able, every time and BECAUSE so many companies sell clear/top coat for spray o chrome!
  28. nicamarvin
    nicamarvin
    from nicaragua
    No. I dont have the same issue.. All I use is 2k Clear coat from Sherwin William an automotive grade Urethane clear coat..
    check my "Flexible Chrome" testing.. http://www.youtube.com/watch?v=6FJCpt1vESA
    the 2K Sherwin william clear coat has never fail on me, at least the adhesion to the silver. whats going to be an issue with adhesion is to plastic. where the entire basecoat will come off due to tha nature of plastics...BUT thats easily fixed with a adhesion promoter, this is ghe glue between the basecoat and the plastic.... I use Krylon fusion but I guess others will work too...
  29. nicamarvin
    nicamarvin
    from nicaragua
    I begg to differ.
    2k Urethane/Polyurethat is the Only coating I use now..
    the Coating is so effective that the plastic will crack first before the spray on chrome gives up on you..
    I belive your issue is using Compressed Air(electrical) this will introduce foreign particles to the silvering process, even the smalles oil particles will produce lack of adhesion of the clear coat..
    there are 3 types of issues with lack of adhesion and their respective resolutions..
    Issue 1.
    lack of adhesion of the entire spray on chrome coatin to Plastic. where the spray on chrome comes off from the base coat(including primer).
    solution: use a plastic adhesion promoter like Krylon fusion
    Issue 2.
    Lack of Adhesion of the Silver layer to the shiny basecoat. where the clear coated silver comes off the shiny(highly gloss) black/white basecoat.
    Solution: this issue is related to the "Chemical Adhesion" glue which in this case is the "Sensitizer" or Tin for silver... the solution is to make the sensitizer stronger or change the sensitizer because it no longer good.
    Issue 3.
    lack of Adhdesion of the Clear coat to the Silver layer. where the clear coat comes off from the silver layer(mirror)
    Solution: there are many possible reason for this, one of the reason is the air is contaminated and needs further flitration. this issue can be solved if one uses clean compressed air on a 2000lbs cylinder..
    I had this issue in the past but I no longer do since using the hand sprayers...
  30. sudzhis
    sudzhis
    from Latvia
    No Nicamarvin, u dont understand me right!
    Yes, it hold on plastc, on metal, but how strong!
    Can u make adhesion test like this?
    <iframe width="560" height="315" src="http://www.youtube.com/embed/K_ccg3qtrzU" frameborder="0" allowfullscreen></iframe>
    like this
    <iframe width="420" height="315" src="http://www.youtube.com/embed/ZY50tJzotq4" frameborder="0" allowfullscreen></iframe>
    Yes, for me it holds on part good, but if u cant make the tests like on video u cant spray any car wheels or car outer parts or bike parts!
