Technical Do I grease "greaseless" tie rod ends?
Discussion in 'The Hokey Ass Message Board' started by Janius, Jun 25, 2016.
  1. Janius
    Janius
    from New Jersey
    I just acquired two sets of NOS tie rod ends for my 60's vintage car. Old timers remember the early "greaseless" fittings... these do not have grease nipples on them and are supposed to be "lubricated for life". Looking inside the boots, they are about as dry as an Arizona dessert. If I put them in can I use an injector needle on my grease gun and pump grease into the boots? Any other suggestions. A few friends said not to use grease as they had nylon inside. Thanks gang!
  2. Jalopy Joker
    Jalopy Joker
  3. verde742
    verde742
    I do know grease eats nylon ..
    destroyed my nylon lawn mower bushings..
    tfeverfred likes this.
  4. tfeverfred
    tfeverfred
    Yup. Grease less means................ no grease. The nylon isn't going to feel "slippery" like it has a lubricant. The chemical make up of the nylon is what let's it work.
    I had a "smart assed" remark, but I'm tired.;)
  5. Janius
    Janius
    from New Jersey
    I did not see any nylon in the tie rod ends, just said that one of my friends said you shouldn't grease nylon. the question is.. what materials did they use in "lifetime lubricated" tie rod ends back in 1969-70 and should they be greased?
  6. alchemy
    alchemy
    Whenever I put tie rods ends on a car they will have grease zerks. I'm not replacing any with those "greaseless" type. Why waste your time? I want to be able to give them a shot at least every spring.
    Bruce Fischer likes this.
  7. mad mikey
    mad mikey
    Yeaaaaa!!! Use ends you can GREASE!!! DOE!!!!:D
  8. 1946caddy
    1946caddy
    from washington
    People own lawnmowers in Arizona?
    Texas Webb likes this.
  9. clem
    clem
    Will the grease go where you think it needs to go, that is with no grease nipple it won't spread throughout the tie rod end/ balljoint.
    What about a squirt of some kind of lubricant - gibbs brand or wd40 ??????
    Although, as others have said it doesnt need to be lubricated.
  10. Janius
    Janius
    from New Jersey
  11. Janius
    Janius
    from New Jersey
    Great idea Mikey and if I could get a set of greaseable tie rod ends that would fit, I would do it... but the reason I posted the question is that I do not have that choice, I have to use what is available.
  12. Janius
    Janius
    from New Jersey
    Again, as I mentioned to Mikey, this is a unique car and the only tie rod ends available are lubricated for life.
  13. clem
    clem
    Then you should be good to go.
    Answer to original 'title' question - No.
  14. Slopok
    Slopok
    If they are lubed for life then why do they need to be replaced?:confused:
    mad mikey and Bruce Fischer like this.
  15. I have Chrysler Polara and every joint has a grease fitting and I keep them greased. Grease is your friend. Bruce.
    mad mikey likes this.
  16. kma4444
    kma4444
    I've, on more than one occasion, drilled joints for grease fittings. Done on high mileage OT cars that were squeaking etc. Not saying every joint wants grease but it's worked for me.
  17. 302aod
    302aod
    from Pelham,Tn.
    I worked at a Ford dealership and replaced many steering linkage parts. Greased for life, means the parts life, not our life.
    270dodge likes this.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It'll love my grease? It'll not love my grease?
  19. BORRACHO13
    BORRACHO13
    from Menifee CA
    If it is lubricated for life then they are good. Even the day they were made they probably looked dry if thats how greaseless joints are right?
    Why would you grease something that says not to? Probably doesn't have the zerk so you don't do it
    just sayin
  20. oldrelics
    oldrelics
    from Calgary
    I've wondered this too, where do you drill n tap em?
  21. sunbeam
    sunbeam
    I remember in the early 60s when car mfg replaced jerks with plugs and bragged about 30,000 mile service intervals. At 30,000 you removed the plugs and put in fittings it saved them a few cents per car.
