Do I have a 216 or 235 ci?
Discussion in 'The Antiquated' started by tuekwik4u, Feb 21, 2025.
  1. tuekwik4u
    tuekwik4u
    Good morning to the group. Purchased this 1968 Nissan Patrol with an old in-line 6 GM motor in it. I am trying to identify the motor, it's either a 216 or a 235. I identified the head, goes on a 55 235ci but I can't find the casting numbers that should be by the fuel pump. All I see is a number 6 and GM. Oil filter housing missing as well. Any recommendations on a aftermarket oil filter housing? Would appreciate any info, thank you. IMG_6004.jpeg IMG_6005.jpeg IMG_6002.jpeg IMG_5998.jpeg
    Okie Pete likes this.
  2. Matt Dudley
    Matt Dudley
    from New York
    216 and 235 were optional oil filters as most engines of that era. You can use a modern day byp*** oil filter mount which is available at Napa and others produced by WIX. Or you can get a filter housing from a swap meet and get it to work.
    first glance is 216 with the pictures provided but it could be an early 235 as well if it came from a Piwerglide car. I can’t decipher those block numbers. Water pumps are different
  3. 302GMC
    302GMC
    from Idaho
    Looking at the oil regulator on the side of the block, & at the casting # on the head, I'd guess it's the one year only '53 Powerglide 235
    TraditionalToolworks likes this.
  4. jimmy six
    jimmy six
    A 53 stick shift had the same “appearance” as a 216 with the 2 bolt rocker cover. A 53 Powerglide had the “appearance of a 54-up”.
  5. 283john
    283john
    Show us a pic of the Patrol in the off topic forum!
