Technical Do I need tubes
Discussion in 'Traditional Hot Rods' started by flyn schlosser, May 14, 2016.
  1. flyn schlosser
    flyn schlosser
    from Elko,NV
    Just bought a set of 4 . 4 inch wide 16 mopar wheels for my 28 coupe . Looking at buying 750 rear and 500 for the front stones either bias or radials .Do i need to run tubes .Any advice is appreciated
  2. gimpyshotrods
    gimpyshotrods
    Probably.
    Riveted wheels are not well known for holding air without special treatment (sealer/welding). The absence of safety beads can allow the bead to walk, causing air loss in the absence of a tube, especially at the low pressures that one would expect to be running with a lightweight coupe.
  3. One thing to keep in mind if running tubes is the speed rating/heat build-up on the tire. If it's a tube-type tire (tubes needed), you'll be ok. If putting tubes in a tubeless tire, you need to reduce the speed rating as the combination of the tubes and the thicker tubeless tire sidewall will hold more heat.
    gimpyshotrods likes this.
  4. flyn schlosser
    flyn schlosser
    from Elko,NV
  5. Barn Find
    Barn Find
    from Missouri
    I've also heard of beads unseating while cornering as a reason to run tubes.
  6. 4 1/2 sounds 'kinda skinny for a 750, ..IMO
  7. flyn schlosser
    flyn schlosser
    from Elko,NV
    What size would you go with
  8. 3wLarry
    3wLarry
    from Owasso, Ok
    this subject has been beat to death on here...4" and 4.5" wide wheels are just fine for 7.00's and 7.50's...guys have been running this setup for the last 70 years with no problems
    Moriarity and gimpyshotrods like this.
