Customs Do I offset the engine?
Discussion in 'The Hokey Ass Message Board' started by ahshoe, Jan 8, 2026.
  1. ahshoe
    ahshoe
    Building another frame, with a small block ford motor and an AOD trans for my 56 F100. The rear end I am using is offset 3” towards the right . A friend of mine said that I should also offset the motor that 3” to the right. Obviously the rear end at the U joint is lower than what the trans will be ….so he said you don’t want the driveshaft to both pitch down and because of the 3” side offset , also pitch to the right those 3”. I have not yet welded in any motor mounts yet and curious if I should do this?
    dana barlow and LOU WELLS like this.
  2. BJR
    BJR
    Center the engine and you will be fine. The offset just makes the U joints work and not develop flat spots on the rollers.
  3. Doublepumper
    Doublepumper
    from OR-WA, USA
    Not a problem. I've done several swaps with offset pinions and never moved anything. Important thing is to make sure the pinion angle is correct for the engine angle.
  4. Find another friend to get advice from
  5. Hollywood-East
    Hollywood-East
    For the Win $)
  6. proartguy
    proartguy
    from Sparks, NV
    Probably as many ideas here as can be posted, but I bought a truck where there was that kind of off set and the first highway drive resulted in the rear seal in the trans giving out and the resulting trans fluid spill had major smoke from the heat. Granted, the truck was low geared with considerable driveshaft speed. With no way to move the engine over I elected to use a double carden front joint from a ‘60s Lincoln suggested by the driveline shop, which worked out well.
    Universals only like to accommodate one direction without problems. Adding another direction (sideways) only adds problems. I prefer to center the pinion to the output shaft by either offsetting the engine or modifying the rear axle.
  7. -Brent-
    -Brent-
    Or just move him 3" away from the garage door... and then close it. Hahaha.
  8. DDDenny
  9. jimmy six
    jimmy six
    You should fill the engine bay….. 5.0 Coyote, early Cammer Ford, Chrysler hemi….
    clem and seb fontana like this.
  10. twenty8
    twenty8
    Millions....... no, wait......... probably BILLIONS of cars running around out there disagree with this statement.;)
    MARKDTN, slayer, 05snopro440 and 10 others like this.
  11. jaracer
    jaracer
    As long as the engine is square in the ch***is and the rear end is also square, the angle at the rear end due to the offset pinion will be exactly the same as the angle at the back of the transmission. Since they are the same, they will cancel and not cause any vibration. Most rear wheel drive vehicle have the pinion off the center line of the vehicle. It does not cause any problem.
    Damon777, bschwoeble, KevKo and 3 others like this.
  12. tim troutman
    tim troutman
    when I built my f1 pick up I used a 64 f100 9 inch which had 2 axles the same length setting it to the right. I set the engine to the right it made sense to clear the steering. When building the wife's 64 f100 I used a front frame section that had the motor centered with the same type 9 inch rear. from what I have read both work but you do not want to put the motor in at an angle to point it at the rear
    Tow Truck Tom likes this.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Rotating 3D imaging will show only one angle, not two.
  14. 31 Coupe
    31 Coupe
    Where were the original engine and transmission positioned. ????
    I'd ***ume that Ford had a good understanding of driveshaft geometry.
    All earlier F100 - 9" rear ends had offset pinions because they used equal length axles on both sides. That positioned the pinion ~2" off center.
  15. I put a zillion miles on drive shafts with more than one angle
    rod1, 05snopro440, das858 and 8 others like this.
  16. Jeff34
    Jeff34
  17. Lots of rods built with the center section “centered” for a uniform visual look.
    Dang crooked drive shafts
    gimpyshotrods and BJR like this.
  18. lostone
    lostone
    from kansas
    There are millions of fords, car and trucks, that have been driven, used, abused, raced etc with offset pinions (9" uhm...) with no problems what so ever.
    U-joints don't see up, down, right, left, level plane, 90° degree plane etc. They only see 1 angle, doesn't matter where the housing sets, its still 1 plane to the u-joint....
    To you the housing nose may be 5° down, and offset 1" inch to the right, you see 2 planes, up/down-left/right but the u-joint doesn't. All it sees is 1 and that where the u-joint connects to the housing...
  19. oldiron 440
    oldiron 440
    How to offset the engine?
    Try installing it centered, it will be off one way or the other.
  20. twenty8
    twenty8
    Universal joints only ever have one angle applied to them at any given time. The pinion might be horizontally offset and vertically offset from the transmission output shaft, but in reality it is only ever a single constantly varying angle that the joint operates at. It is called a "compound angle", and as long as it is within the maximum recommended operating parameters, all will be ok.......:)
  21. 57Fury440
    57Fury440
    A lot of Chrysler Corp. cars had their motors offset in the sixties and later.
    bschwoeble likes this.
  22. Toms Dogs
    Toms Dogs
    from NJ
  23. willys36
    willys36
    You could move the frame over 3". Or better yet, move the frame 1 1/2" and the engine 1 1/2".
    TwistedMetal, clem and Kerrynzl like this.
  24. 69fury
    69fury
    from Topeka
    Just tilt your head 45 degrees to the side and you'll see the same thing the ujoint sees. Since it rotates, there is only one angle and it's measured in "X" degrees from straight.
    Another way to visualize is to get 2 laser pointers, put one on the trans yoke and one on the pinion yoke, blow some baby powder or smoke in between to show the lines and observe the physical distance between the beams. That distance is where the angle comes from, not which line is left/right/higher/lower.
    -rick
  25. The offset will cause the ride to track crooked if you don’t change the thrust angle of the rear to compensate the offset. :)
    dog leg like an old ford truck with frame damage.
    (Sarcasm. This is BS)
    05snopro440 and 427 sleeper like this.
  26. theHIGHLANDER
    theHIGHLANDER
    Pinion offset, isn't the actual measure considered as ½ for offset purposes? I bought a lot of axles and narrowed a **** ton (a bit less than a **** load) of housings, and a distant echo is telling me this truck offset is actually referred to a 1½". Feel free to correct my recollection. GMs were ½, Mopars were ¾, Fords were either/or, some ½ and some ¾. Be gentle with me, that was more than 30yrs ago:oops:
    427 sleeper likes this.
  27. whiteknuckle
    whiteknuckle
    from Dryden, NY
    As a mechanical engineer retired from the auto industry I just love these posts. If you're going to be wrong, be aggressively wrong. Kudos to people that can view things in 3D.
  28. twenty8
    twenty8
    Is it this one? If it is, it has nothing to do with engine/pinion offset.
    theHIGHLANDER and 69fury like this.
  29. Johnny99
    Johnny99
    That’s the old HAMB right there!
  30. BJR
    BJR
    We need to get some terms in order here. Someone please put these terms in order from the least to the most, or smallest to largest.
    Zillion
    Millions
    ****load
    **** ton
    Billions
