1952-59 Ford Do I really need dust shields on disc brakes
Discussion in 'Off Topic Hot Rods & Customs' started by shortshift, Nov 24, 2025.
  1. shortshift
    shortshift
    Thinking about converting to disc brakes on the 54. Some sellers dont offer dust shields.
  2. snoc653
    snoc653
    from Iowa
    Many a car has ran fine with disks and no dust shields. As the name implies, they help shield the disks from dust, rocks, and leaking fluid that may degrade braking and potentially damage the rotors or other components. The choice is, “what are you comfortable with?”
    Bill's Auto Works likes this.
  3. squirrel
    All factory built cars come with them. Few hot rods have them.
    You can decided yourself, what you want to do.
  4. gene-koning
    gene-koning
    I have never added dust shields on any disc brake conversion that did not come with the dust shields. However, if the disc brakes were donations from a vehicle that already had the dust shields, I did not remove them unless the shields were damaged. I have never replaced a damaged shield, and if one side was removed, both sides were removed.
    Guess maybe I was too lazy to create dust shields for disc brake conversion kits that did not come with the shields. I tend to put a ton of miles on the stuff I build, never had a problem with missing disc brake dust shields.
  5. RodStRace
    RodStRace
    If you run dust shields, does that mean you must run wheels with tiny gaps in the face too? ;)
  6. mohr hp
    mohr hp
    from Georgia
    The Willys in my Avatar has narrowed Econoline axle with a GM metric disc conversion and no shields. I don't know about dust, but in a heavy rain, my brakes are for ****! I think the splash from one wheel floods the opposite disc.
  7. Ned Ludd
    Ned Ludd
    I think they're more about keeping brake dust in than road dust out.
    I've always thought that that's the Good Reason to go with the Real Reason of finding more uses for open-loop recycled plastic.
    twenty8 likes this.
  8. AldeanFan
    AldeanFan
    I did not add dust shields when I converted to disks on my ‘54 country squire,
    same when I upsized the brakes on my mustang.
    On my tundra, the dust shields turned to dust themselves years ago.
    all of these have been fine and I don’t miss the shields in any way.
  9. twenty8
    twenty8
    That's what I thought too, especially for alloy wheels. Keeps the wheels clean. Brake dust can be hell on alloy wheels.
    Some wheels seem to need them, some not. It has to do with air flow direction through the wheel when it is rotating.
    Ned Ludd likes this.
  10. squirrel
    all the OEM dust shields I've seen cover the inside of the rotor, not the outside, so they do nothing for brake dust on wheels.
  11. RodStRace
    RodStRace
  12. little red 50
    little red 50
    Except maybe make it worse.
  13. twenty8
    twenty8
    It seems we are talking about different things.:confused:
    Some cars here in Australia have a shield between the rotor and the wheel to keep brake dust off the wheel.
  14. pprather
    pprather
    I suggest the inside dust shields help prevent road trash from getting picked up and wrapped around the rotor.
    Deuces, down-the-road, SS327 and 2 others like this.
  15. RodStRace
    RodStRace
    I'd guess that they kept trash out but also shielded the ball joints from radiated heat under extreme use.
    Deuces and down-the-road like this.
  16. I never use them. And actual that vast majority of factory disc applications had no dust shields. Like my 97 Monte Carlo for example
  17. squirrel
    huh...we have 4 cars with OEM 4 wheel disc brakes, they all have them at all wheels.
    down-the-road, SS327 and Dick Stevens like this.
  18. Dick Stevens
    Dick Stevens
    I can't recall ever seeing any OEM disc brakes that didn't come with dust shields!
    down-the-road, SS327 and squirrel like this.
  19. squirrel
    just for fun I looked at a 1998 Monte Carlo on bat, which has nice pictures of everything, and no dust shields. Interesting. I've never noticed any other modern cars not having them.
    down-the-road and Dick Stevens like this.
  20. gene-koning
    gene-koning
    I can say I have never seen any factory dust shields between the rotor and the wheel, but then again, I don't mess with too much modern stuff. I have seen aftermarket pieces that were intended to be installed between the rotor and the wheel, but those were mostly designed to keep the brake dust off the wheels. I would think that the dust shields would reduce the rotor cooling to some extent, having both sides of the rotors covered would be 2x as bad.
    I have also seen a lot of older cars with messed up dust shields that someone had poorly attempted to straightened, or had been removed.
    I could see where the rotors could be covered with splashed water under certain conditions, but a touch of dragging the brakes before you needed them would solve that problem.
    I suspect the entire reason they have been installed on new vehicles for years was because some bureaucrat, sitting in some office, with no understanding of anything automotive, thought they needed to be there.
  21. Dick Stevens
    Dick Stevens
    I seriously doubt this, they always seem to do what is cheaper so the profit margin is better
  22. squirrel
    or they do what will be necessary to prevent lawsuits that would cost them more than the cost of adding the parts, more likely.
  23. chevyfordman
    chevyfordman
    My roadster has dust shields on the front and rear disc brakes.
    pprather likes this.
  24. Ned Ludd
    Ned Ludd
    It seems counterintuitive, but industry is set up actively to generate the most expensive practical methodologies. The reasons for this are complex, and elaborating them will take us into serious OT territory. But for this to work industry players have to be prevented from breaking ranks and undercutting the rest, very often through legislation.
  25. Sharpone
    Sharpone
    From one of the brake gurus on Gr***roots Motorsports
    “from the OE side, consider this: if i could eliminate two part numbers from the bill of materials for my vehicle, plus the ***ociated cost and weight savings from deleting those parts, i'd be a berkeleying hero.
    the reasons OE's use them have all been touched on by previous posts. it's a combination of splash and gravel /dirt protection, thermal protection for suspension parts (don't want to liquidate all the ball joint / tie rod end grease or burn off the boots), and airflow management.”
    Dan
    down-the-road, squirrel and RodStRace like this.
  26. X-cpe
    X-cpe
    Shades of driving through puddles with drum brakes.
    Sharpone likes this.
  27. gene-koning
    gene-koning
    Wet braking surfaces don't work well until the water has been displaced. Some people believe that the process the brakes use to function are somehow different between disc and drum, they don't realize that the friction is what causes the brakes to work.
  28. squirrel
    what happens to water in the brakes is quite different with disc and drum :)
    rockable and blue 49 like this.
  29. Sharpone
    Sharpone
    Water affects drums worse than disks. As a side gig I sometimes haul the Amish around. One day my Amish friend Chester says “I need to get some dot3 brake fluid” I ask pray tell what is an Amish going to do with brake fluid?
    Chester tells me it’s for his buggy brakes I ask you have hydraulic brakes? Yes says Chester I have drums on my old buggy and disks on my new buggy. I told him I thought all the buggies had scrub brakes. Some do but drums are better and disks are best. The disks aren’t affect by water as bad he tells me. I tell ya I learn something everyday.
    We live in a very hilly region with a fair amount of moisture and scrub brakes are iffy at best.
    Dan
    RodStRace likes this.
  30. Sharpone
    Sharpone
    Next time I’m at Chester’s I’ll look at the buggy brakes a little closer. I’m sure the drums had a backing plate/dust shield but don’t remember if the disks did.
    Dan
    SS327 likes this.
