Do you clip the dingle?
Discussion in 'The Hokey Ass Message Board' started by sloppy-ollies, Apr 9, 2009.
  1. sloppy-ollies
    sloppy-ollies
    from Jersey
    I'm referring to the little ball that forms on the end of MIG welding wire after each arc. I clip them each time, I think it helps. Does everyone else do the same? You think it matters?
  2. oilslinger53
    oilslinger53
    from covina CA
    I clip the end every time the wire stops feeding for more than a second or two, but not every time I make a puddle. and yes. It makes a noticable difference
  3. weemark
    weemark
    from scotland
    nope I dont clip them.. ive not noticed a difference.
  4. scottybaccus
    scottybaccus
    Only if I am doing something for the very best appearance. I also cut the wire back if it is too long. It's strictly about the amount of filler as you start the weld, IMO.
  5. hotroddon
    hotroddon
    Depends. A lot of how those form have to do with the heat vs. the wire speed and the method with which you end you bead (pulling away etc.)
    But yes if you have a big *********** it will make for a cold and bubblegum looking start of a new bead, so cut it off.
  6. Depends on thickness of the steel I'm welding...clip for thin wall or sheet metal..don't bother for plate.
  7. i do if i want what i'm welding to look nice. if i'm blowing together something like an engine stand or fixture i just let it go
  8. Shaggy
    Shaggy
    from Sultan, WA
    I'm no expert, but thats what i do
  9. sjrodder
    sjrodder
    from vermont
    When i do production work I don't clip the end but I will when doing small percision welds. I like to TIG most of my rod stuff.
  10. oldrelics
    oldrelics
    from Calgary
    Always clip, makes big difference on sheetmetal...
  11. OGNC
    OGNC
    My parents made the decision to clip my dingle before I came home from the hospital...
    Oh wait, you were talking about mig welders. Yes, I always clip to keep from having too much filler at the start of the weld...
  12. hotroddon
    hotroddon
    Like you know how to weld magazine boy :D
  13. TagMan
    TagMan
    "My parents made the decision to clip my dingle before I came home from the hospital... "
    Wow, talk about TOO MUCH information.........:D
  14. RotHod
    RotHod
    from So Cal
    Yes I do every time even when I think maybe I wont this one time, OCD I guess.
  15. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I clip it..my reason behind doing it..is the sharp tip on the wire helps with starting the next arc..
  16. von rigg is right. that little angle does make for less metal for the welder to try burn. as for myself, if i did clip every time i started a fresh weld my old boss would still be going ******* because id still be finishing all the work i did for him.
  17. I had always gave the gun a little flick after each weld and the ball flies right off no need to clip.
  18. burninbilly
    burninbilly
    always clip gives you a positive start,that dingle is dead
  19. 29nash
    29nash
    from colorado
    I noticed a welder that worked in shop where I was foreman that did that a lot, on 'by the hour work', but when he did a 'flat rate', 'bid job', clipping (or anything else) that slowed him down was very infrequent:eek:
    With a Mig, I never cared. I clip it if it ends up too long because I withdrew before I released the trigger. ....Well sometimes........:cool: When that happens, there's a short dab of wire mixed up in the startup. I purposly leave some of those, just to attract "spectator-weld-critics".:eek:.
    What happens if you don't clip it? If it matters to the quality of the weld, I'm kind of doubtful. As always, starts and stops create turds anyhow, not clipping it might leave a 'different kind' of turd on startup, but, oh well.... .:D
  20. mottsrods
    mottsrods
    If you're getting the little ball on there, then you have your wire speed to high for your voltage. Some welders, like Esab, have a burnback control to help with that. But, it isn't hurting anything for it to be there because as soon as you strike the arc, and if your metal is clean, it's gonna melt into the puddle.
  21. mottsrods
    mottsrods
    Then wouldn't that make you "TagGirl"?????
  22. ol'skool29
    ol'skool29
    as much as i WANT to cut it off when starting a new bead, im just too lazy to go to the toolbox on the other side of the garage to get the cuttin' pliers, so i just weld away (i just did this today as a matter of fact!)
  23. I get to be one lazy SOB too. Just weld on.
  24. 49ratfink
    49ratfink
    lazy sob's... I have a pair of snips in a holder welded to the side of my welding cart. they are usually in my pocket while welding.
    I snip when doing sheetmetal most of the time. not as much with the thick stuff.
  25. Flatheadguy
    Flatheadguy
    Yes. Out of habit, but I have no idea why.
  26. Belchfire8
    Belchfire8
    I did the same thing when production welding on steel rule dies...usually made a nice splash of sparks when it hit the floor. :rolleyes:
  27. Goldchainer$$$
    Goldchainer$$$
    from L.A.
    i clip and wire brush. I have OCD
  28. ol'skool29
    ol'skool29
    all i need to do next time is to get the snips BEFORE i weld! haha :rolleyes:
  29. Never did before, but I'm going to try it now. Thanks for the idea..... if it works! Luke
  30. I Drag
    I Drag
    I blip it against the ground clamp sometimes to blaze the dingle off or if the wire's too long. I used to clip, but I got lazy. Am I a hack or what?
