Hot Rods Do you have heat in your hot rod or custom?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Dec 6, 2022.
  1. 49ratfink
    49ratfink
    heat good. cold bad.
    many old timey heaters are little art deco works of art. here's a few cool ones.
  2. Heat and defroster are a must for me. No A/C, that's what cowl vents and windows are for! If I ever need to reupholster the seat, it'll get electric seat heaters! A warm wife is a happy wife!
    Algoma56 likes this.
  3. dana barlow
    dana barlow
    from Miami Fla.
    Ok,no,never even thought about it!
    Miami Fla. has about a week of under 65*,so nope!
    wicarnut, Lil 32, 210superair and 2 others like this.
  4. mad mikey
    mad mikey
    No heater, that would just slow it down.;)
    mario711, charleyw, MMM1693 and 3 others like this.
  5. ccain
    ccain
    Lived back east most of my life until I wised up and moved my delicate **** to Southern California.
    It's funny how easily you get acclimated. Now if it gets below 50, I've got the heated seats on in the family hauler. :D:D:D
    But, sadly no, not in the old truck. There is a heater under the dash but the core is shot and the heater hoses are byp***ed. I have yet to locate a heater core to fit it, but when I do, she's getting heat. Like I said, I'm delicate. :p
  6. lostone
    lostone
    from kansas
    Like jokester said, it's kansas so you can leave in the morning at 35° and drive home after work the same day and be using the a/c.
    So my 31 will definitely have heat. I'm too old and have enough joints that hurt when it's cold so anything I can do to keep the joints warm I'm all for in cold months.
  7. 4speed411
    4speed411
    No heat, radio or power accessories... it's a Hot Rod
  8. twenty8
    twenty8
    Not entirely true. How many cubic inches of supercharged heater are you running ???
    mad mikey likes this.
  9. I remove the trans cover.
    That’s the only heat I have
    had to lean forward this morning to work the manual wiper.
  10. gimpyshotrods
    gimpyshotrods
    Yup, AC, too.
    Even my show rod will have both when it is done.
    Why build something that is uncomfortable to drive?
    i.rant, 57JoeFoMoPar and rockable like this.
  11. gimpyshotrods
    gimpyshotrods
    What truck is it?
  12. hemihotrod66
    hemihotrod66
    Don't want to drill holes in my firewall...Does get chilly here in Vegas but just put on thicker coat...
  13. gimpyshotrods
    gimpyshotrods
    Pull the dash rail, and cut into the face of the tank.
    Make deflectors that send the air towards the windshield. Make hose adapters for what was the inside of the tank.
    The dash rail will cover the deflectors so they won't be seen.
    UnkkaBobby, chryslerfan55 and OFT like this.
  14. Stan Back
    Stan Back
    Only one time while trying to start it, I kept pumping the tank and not holding any pressure (a sign of low fuel in a 10-gallon tank), and eventually lit off a couple of the six 97s' overflow on the engine.
    Luckily the guys in the pressroom p***ed a m***ive fire extinguisher out the window and I put out the flames. Walked home at 1 a.m. and came back the next day in daylight conditions.
    ClayMart and chryslerfan55 like this.
  15. knucklenutz
    knucklenutz
    Not sure of the origin. It was a 5 dollar "gift" from a great friend. It keeps Canned Heat, my '29 Tudor nice and toasty on cold Wisconsin fall mornings. P1050029.JPG
  16. I'll be the odd man out. Vintage Air is one of the 1st things I install when building a rod. I drive my stuff year 'round which means snow and cold and 110 degrees in the summer. I haven't had a roadster since 2007 but I might find I don't enjoy that exp. as much as I used to. Age is a factor. Many can laugh but if you get the privilege of living long enough, you will probably find out what people are talking about. Where I live, a close event is 200 miles one way. You can have 35 degrees in the morning and a wonderful 85 in the afternoon. I handle heat way better than cold. However, a fogged up windshield is dangerous and I don't want to be the cause of an accident. :)
  17. BamaMav
    BamaMav
    from Berry, AL
    I’m in the process right now of putting in a Vintage Air Gen II compact with AC, heat, and defrost. Got the evaporator hung today, going to start on the heater hoses maybe tomorrow. Still got to get the AC hoses, compressor and condenser.
    My car had under the seat heaters, but they were rotten. It had a separate core on the firewall for the defrost, I was using it for heat, but it just wasn’t enough to do much more than take a chill off. The Gen II should make it comfortable year round. We can have all four seasons in a day temperature wise. Heat in the morning, AC in the middle of the day, heat again after dark.
    gimpyshotrods and chryslerfan55 like this.
  18. jaracer
    jaracer
    While it doesn't get real cold for very long in Oregon, I did put a Montgomery Ward heater in my Model A. It heats the small space quite well. The knob above the heater controls the water valve. Toggle switch for the fan. IMG_1536.JPG
  19. ccain
    ccain
    '60 F-100. I don't believe this is a factory unit. I tried to find a core for it a few years ago using the measurements, but never came up with anything.
  20. I've got heat and a/c, sort of.
    There was a big ball, rat nest of wires under the dash when I got my '50 Chevy truck a few years back. I didn't turn anything on if I could get by without it. That got to be a habit. Two years ago a new harness cleaned it all up but I haven't gotten around to charging up the a/c yet. Nor have I tried to figure out the heater controls yet.
    I roll the windows down when the weather is hot and roll 'em up when it's cold.
    (I just drive mostly around town. No trips.)
  21. blue 49
    blue 49
    from Iowa
    I've got this heater in my '36 Ford pickup and it works pretty good even with the crude core I made for it. If I had door gl*** it might even get toasty in that small cab. My henryJ has all it's windows but no heater.
    Gary
    chryslerfan55 and knucklenutz like this.
  22. Rand Man
    Rand Man
    No heat in my coupe. I’ve driven it as low as 18 degrees F. Model A coupe is so small, it doesn’t matter much on a short trip.
    Charlie K and lothiandon1940 like this.
  23. theHIGHLANDER
    theHIGHLANDER
    I do. S E Mich, might be 72 all day and drop to 48 that night. Gotta have it, but y'all gotta wait for a performance report and I'm fairly confident. Got this from @***us and restored it with a 12V motor from NAPA. Also have defrost tubes, just close the doors to increase the function, and I have a vacuum fan to blow across the gl*** as well for those steamy summer nights.
    20201230_184336.jpg 20201230_191341.jpg 20201230_142338.jpg 20201230_184429.jpg 20210104_192410.jpg
  24. OFT
    OFT
    I have a Hot rod air unit. For defrost, I used the deforest ducts from late 40 "something" made of metal. Drilled number of holes in the windshield lower flange to match position. Seems to work ok. Getting ready to go pick a friend up at 6 tonight, at 24* here in Idaho. Model A door gaps, put towels to stop air flow along seat edges-lol
    knucklenutz likes this.
  25. Almostdone
    Almostdone
    Yes siree, heat and AC for me.
    Some days I use heat in the morning and AC in the afternoon. The AC was really worth its weight when my wife drove the car 150 miles to Hot Rod-a-Rama in eastern Oregon last summer…. 105 degrees, 70 mph, and she didn’t stop once.
    What’s that phrase? Happy wife, happy what?
    John
  26. Canned Heat ehh? Does that mean you’re umm, going up the country? lol
  27. warbird1
    warbird1
    I restored the original heater from my '40 as I was going through the rest of the car. Then decided to swap the Cad in it; so had to move one of the tubes to clear the distributor and added some beads to both of them to better retain the hoses under pressure, though I'm only running a 7 lb. cap on the radiator. Works great; it's throwing heat within 3 min. after start-up!
  28. A 2 B
    A 2 B
    from SW Ontario
    Here in Ontario a heater that is capable of defrosting the windshield and front side windows is actually a safety regulation/requirement. I converted to a 12V system so plan to rebuild this one with a new motor.
    Princess Auto have these in their flyer this week. Wow 36,000 BTU, I could drive all winter with the windows down. LOL Heater 1.jpg
    chryslerfan55 and lothiandon1940 like this.
  29. nochop
    nochop
    from norcal
    Same heater I have
  30. Just.dale
    Just.dale
    BB3F0ACB-5AE2-4203-87E5-B3EFD9B56EF2.jpeg Takes the edge off of Jersey winters!!!
