Hot Rods Do you have heat in your hot rod or custom?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Dec 6, 2022.
  1. 49ratfink
    49ratfink
    I restored a few in my ebay days. I found if they don't have green crust on them they probably won't leak. never had a motor that would not work with a new wire. the cloth covering wears out and the shorts on the housing. here is some before pics and my Special High Intensity Testing setup to check for leaks.
    excuse my sideways pics
  2. D-Russ
    D-Russ
  3. rockable
    rockable
    No heat, no AC, me no drive. My 48 Buick had Vintage Air in it but the top is not snapped to the frame on the sides. It ****ed out heat or AC like a vacuum cleaner. That is one reason I got rid of it. I am not going to be uncomfortable in my cars.
  4. primed34
    primed34
    No. There have been a few trips that I wished I had one.
    210superair likes this.
  5. gene-koning
    gene-koning
    Heat with defrost in everything around here. One of the higher priorities, right there with functioning wipers. I want to be able to see through the gl*** in the stuff I drive.
    The 1st car (35 Dodge 2 door sedan) I put heat in only for defrosting the windshield. All the air out of that small heater went to the windshield, but I soon discovered it did a pretty nice job at warming the car up if I could cut down the air drafts from around the doors and holes in the firewall.
    My coupe has great defrost, and pretty good heat (still too many cold air drafts) No ac in it, but it has fresh air vents and roll down windows that work pretty good. The car is tolerably warm from about 35 degrees and can be tolerably cool enough up to the upper 80s.
    My 49 truck will roast you out in 15 minutes @ below 0 temps. There is a fresh new AC evaporator in that heater box, but the AC is not there yet. The truck has roll down windows and a fresh air vent like the coupe, but AC may arrive at some point.
    One time we took the trip to the Hundrt Car Pileup in my son's car. It had no heat at all. The temps were only suppose to get into the 30s all day, and it was a 5 hour drive one way. The night before I bought a 10' roll of copper tubing and connected it to the motor's cooling system. Even with out a fan, it made the front seat at least a little better. There were 3 of us guys that made that trip, so someone sat in the back seat. About every hour we stopped and everyone rotated positions. We had a ball at the show, but we were all pretty happy to get back home to the warm house!
    You guys understand a heater is nothing more then a small radiator connected to your cooling system with a fan mounted on it to blow air through it? The outside cover is simply there to pretty it up and direct the air. If you have slots in the panel in front of your windshield, and point the air up behind you dash, any air that hits the windshield will clear it, at least where the air hits it. The duct work simply directs the direction of the air flow. Then after the air bounces off the windshield and the roof, it will go back into the rest of the car. You can control the hot air with fan speed, and water flow control. Heat/defrost can be as simple as you want, or as complicated as some modern stuff is.
    chryslerfan55 and Algoma56 like this.
  6. Mr48chev
    My Buddy Ron Moore and his wife Sharon used to drive their 29 Roadster with their snowmobile suits and helmets on in the winter.
    My 48 was so drafty when I first had it in Texas that I froze My **** off in the winter heater and all driving to work from McGregor to Waco every day but 20 degrees in Waco equals 0 here as far as chill your bones goes.
    Truth be if you are actually going to drive your hot rod or custom on serious road trips you want a heater that will work. I've froze my **** off the last week of June going over a p*** in Colorado on the way to Texas and two weeks later woke up in Jackson Hole Wyoming with ice on a puddle on the side of the road in July. When the sun goes down in some of those areas the very nice day time temp drops to flat *** cold at night.
    warbird1 and chryslerfan55 like this.
  7. Blake 27
    Blake 27
    I found a nice old Arvin heater, put a modern Spal fan on it with a two speed switch from Ron Francis. I'm extremely happy with the amount of heat
    it delivers, especially with my side curtains installed.
    OFT, Roothawg, jim snow and 8 others like this.
  8. gimpyshotrods
    gimpyshotrods
    Transmission, or oil cooler.
    Both are essentially heater cores.
  9. XXL__
    XXL__
    Firewall and floorboard heat year round. Gloves and coat in winter.
    Charlie K and 210superair like this.
  10. mgtstumpy
    mgtstumpy
    Not in my Chevy phaeton however I've thought about an old art deco style heater / defroster and still run the cowl vent in summer. Insulation under cowl and floor make it comfortable.
    The 46 Olds is getting it along with the full dyna-mat treatment, it gets cool here in winter and HOT in summer. Retaining the factory air, 1/4 and cowl vent.
    No heater or vents in the 64 Fairlane, damn HOT even with 1/4 vents and windows open
    Lil 32, chryslerfan55 and 210superair like this.
  11. T. Turtle
    T. Turtle
    One of the first things I fixed on my car was the heater which was leaking and by-p***ed. Where I am in Central Europe it can get a bit chilly during spring and fall, I see no reason why I should suffer. Thinking about fitting a valve to isolate it in summer though.
  12. theHIGHLANDER
    theHIGHLANDER
    Good place to ask, show of hands, who has and what kind of coolant shutoff do you have for summer? Does it work on a long drive or will the core eventually heat up (seems to me it might)? I plan to use an early Ford F-series/Bronco valve and a cable inside, but if there's something better...
  13. HEATHEN
    HEATHEN
    from SIDNEY, NY
    When I had to byp*** the factory shutoff valve in my '53 Chevy due to it leaking, I used one for a late '60s/early '70s Mopar with a choke cable hooked to it.
  14. 210superair
    210superair
    from Michigan
    I don't have one in the shoebox, but x2 in that there's been a few times I wished I did. Not many though, i don't drive it in the winter due to salty roads. However, some of the cool designs posted here make me tho may add one of those anyway! Some really cool looking designs.
  15. Elcohaulic
    Elcohaulic
    I'm going to run 1/2" copper tubing inside the cowl of my el Camino. I'm going to put a gate valve on the engine side of the cowl. This way if it leaks, the water will go down the gutter and out.
    When I open a floor vent the heat will come out.
    I can't find that heat tubing with the tin foil wrapped around it.
    Or maybe a mount an oil cooler under the dash or inside the cowl.
    chryslerfan55 and lothiandon1940 like this.
  16. bschwoeble
    bschwoeble
    My kind of heat.
  17. woodiewagon46
    woodiewagon46
    from New York
    I have a heater in my '46 Woodie but don't have one in my Deuce roadster. For my roadster when the weather gets cold I have been using a heated vest sold by motorcycle shops. It plugs into a cigarette lighter socket and when I use it under a coat it really keeps me warm.
  18. 36cab
    36cab
    My best heater story. My buddy Matt is thermically challenged and cannot stand the cold. Why he continues to live in Iowa is anyone’s guess. I was riding shotgun in his survivor 32 5-window hot rod coming back from The Hunnert Car Pile Up in Morris Illinois. I don’t remember what year it was but it was the year that was bitterly cold. As we are driving west on I80 through the snow flurries, a gap in the body was blowing frigid air directly up his left pant leg. His complaining and whining about being cold went on for miles. I finally asked him if his engine had a supercharger on it. He looked at me like I was nuts since I knew it did not and since the coupe was hoodless you could clearly see the tri-power on the small block Chevy. Matt answered “no it does not” and I replied “then the whine I’ve been listening to for the last 50 miles must be you whining about the cold”. He laughed and although he was still freezing he did stop complaining. But as soon as he got home he started gathering parts to build a heater for the coupe. Matt bought another 32 5-window earlier this year and the first thing he did to it was install a heater.
  19. bobss396
    bobss396
    I have great heat in my Ford. I had the dash out so it was easy to go through everything. I pressure tested the heater core and lubed up all the cables. I have driven the car as low as 3* out and was comfy.
  20. 57 Fargo
    57 Fargo
    Since I use my old cars for driving like they are meant to, yes I have heaters in them.
  21. HRBOB34
    HRBOB34
    I have heat and ac in all my hotrods!
    At 69 years old its hard to go with out!
    bobss396 likes this.
  22. 1971BB427
    1971BB427
    from Oregon
    If I had heat in my old Austin g***er the heater box would stick into the p***enger compartment so far anyone sitting on the right seat would be banging their knees on it. The dash is only about 4" deep, so I've never seen a heater thin enough to fit it?
    I'd like to put a heater in my '39 Chev coupe, and have plenty of room. But haven't found the right one yet.
  23. 57JoeFoMoPar
    57JoeFoMoPar
    I didn't have heat in my cars for the longest time. Then a few years ago I acquired cars with heat and a/c, and I have to tell you, it has made a significant difference in the ability to use the cars. I log a lot of miles with them, which is mainly time spent not going to shows, but just going places. Whether it is to visit friends, running errands, trips to the grocery store or Walmart, going to the rink for a game, to take my kid to the park... I can take an old car because my family is comfortable for ride. I don't have to twist my wife's arm to ride in a car that they're freezing in or sweating to death in, and it isn't a coincidence that the car with no heat has sat undriven in the garage for the last 2 years.
    Algoma56 likes this.
  24. Heat yes, A/C no. My 53 Chev has dealer installed heat.
    I don't use the A/C in my 09 Chevy truck, and I don't have A/C in my house, it makes me sick to my stomach going in and out of it.
    05snopro440 likes this.
  25. CME1
    CME1
    I haven't installed heaters or ac in my old cars in the past. Now that I am 80yo I am more sensitive to the heat and cold. So yes, I have Vintage AC and Heat in my 1942 Ford.
  26. the flatlander
    the flatlander
    That is a real *****in' thing there. Mine's usually Mexican carry....if downtown.
  27. the flatlander
    the flatlander
    sing it brother, know exactly what you mean !
  28. Blake 27
    Blake 27
    I used a gas style ball valve for my shutoff which I can easily reach from the drivers seat .
    Ball valves are usually preferred over gate valves.
    joel, bobss396 and Lil 32 like this.
  29. sidevalve8ba
    sidevalve8ba
    Yes, I do. Courtesy of J. C. Whitney, many years ago. Keeps my little truck very comfortable. CIMG1171.JPG
    Turn on the heater, Peter. I think we're gonna need 'er!
  30. neilswheels54
    neilswheels54
    What did you use for hardlines on this, looks tidy
