do you own any of these tools?
Discussion in 'The Hokey Ass Message Board' started by max wedge kid, Apr 1, 2011.
  1. max wedge kid
    max wedge kid
    DRILL PRESS: A tall upright machine useful for suddenly snatching flat
    metal bar stock out of your hands so that it smacks you in the chest and
    flings your beer across the room, denting the freshly-painted project which
    you had carefully set in the corner where nothing could get to it.
    WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the
    workbench with the speed of light . Also removes fingerprints and
    hard-earned calluses from fingers in about the time it takes you to say, 'Oh
    shit!'
    SKIL SAW: A portable cutting tool used to make studs too short.
    PLIERS: Used to round off bolt heads. Sometimes used in the creation of
    blood-blisters.
    BELT SANDER: An electric sanding tool commonly used to convert minor
    touch-up jobs into major refinishing jobs.
    HACKSAW: One of a family of cutting tools built on the Ouija board
    principle... It transforms human energy into a crooked, unpredictable
    motion, and the more you attempt to influence its course, the more dismal
    your future becomes.
    VISE-GRIPS: Generally used after pliers to completely round off bolt heads.
    If nothing else is available, they can also be used to transfer intense
    welding heat to the palm of your hand. They can also be used to sculpture
    your wife's nose when they fall from a motorhome TV antenna!
    OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
    objects in your shop on fire. Also handy for igniting the grease inside the
    wheel hub out of which you want to remove a bearing race.
    TABLE SAW: A large stationary power tool commonly used to launch wood
    projectiles for testing wall integrity.
    HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after
    you have installed your new brake shoes , trapping the jack handle firmly
    under the bumper.
    BAND SAW: A large stationary power saw primarily used by most shops to cut
    good aluminum sheet into smaller pieces that more easily fit into the trash
    can after you cut on the inside of the line instead of the outside edge.
    TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of
    everything you forgot to disconnect.
    PHILLIPS SCREWDRIVER:
    Normally used to stab the vacuum seals under lids or for opening old-style
    paper-and-tin-foil oil cans and splashing oil on your shirt; but can also be
    used, as the name implies, to strip out Phillips screw heads.
    STRAIGHT SCREWDRIVER:
    A tool for opening paint cans. Sometimes used to convert common slotted
    screws into non-removable screws and butchering your palms.
    PRY BAR: A tool used to crumple the metal surrounding the clip or bracket
    you needed to remove in order to replace a 50 cent part.
    HOSE CUTTER: A tool used to make hoses too short.
    HAMMER: Originally employed as a weapon of war, the hammer nowadays is used
    as a kind of divining rod to locate the most expensive parts adjacent to the
    object you are trying to hit.
    UTILITY KNIFE: Used to open and slice through the contents of cardboard
    cartons delivered to your front door; works particularly well on contents
    such as seats, vinyl records, liquids in plastic bottles, collector
    magazines, refund checks, and rubber or plastic parts. Especially useful for
    slicing hands and work clothes, but only while wearing them.
    SON-OF-A-BITCH TOOL:
    (A personal favorite!)
    Any handy tool that you grab and throw across the garage while yelling
    'SON-OF-A-BITCH!' at the top of your lungs. It is also, most often, the next
    tool you will need.
    <!-- / message --><!-- sig -->
  2. oddrodd
    oddrodd
    from Michigan
    Don't care for the son-of-a-b!tch tool. I have to keep buying a new one.
  3. redram53
    redram53
    from dallas, nc
    Max wedge, This is funny as hell. I'm still horselaughing. I have just about every one of these. Just can't seem to find my son of a bitch tool anywhere.
  4. fearnoevo
    fearnoevo
    from Iowa
    One of the toughest questions I have ever had to answer was the following from my Dad; "Where in the hell is the 9/16 wrench".
    My very hesitant response, "Over there Dad, stuck in the wall from when you threw it a minute ago."
    Decorum prevents me from posting his response to me.
  5. WM3
    WM3
    btt
    This is too damn funny!
  6. SOHC427
    SOHC427
    Yes, yes, and all tools have been used as their description states......
    Funny stuff!
    Eric
  7. Midwest Rodder
    Midwest Rodder
    I have to say that reading this has just made my bad day at work better. Still laughing my ass off, thanks!
  8. Mr.Musico
    Mr.Musico
    from SoCal
  9. FoMoCoPower
    FoMoCoPower
    only about the 10000th time this was posted
  10. 41chevytruckinga
    41chevytruckinga
    still laughing. that was great! i remember the SOB tool that dad had! only it was a MFer tool then. its also good for breaking all the baby jars full of nuts, bolts and washers that are hanging over work bench.
  11. thunderbirdesq
    thunderbirdesq
    Still funny for some reason...:D
  12. 76cam
    76cam
    WOW how did you get in my shop!!!!!!!! lol that is spot on.
  13. cyclesounds
    cyclesounds
    Sounds like the tools in my garage.
  14. Racrdad
    Racrdad
    I think you forgot this one:
    MIG WELDER - easily transforms small pinholes in sheetmetal into larger gaping holes that require a patch then be welded in. Of course this then leads to use number two: Very effective in warping sheetmetal into wavy rippled surfaces that require hammering and body filler.
  15. Bruce A Lyke
    Bruce A Lyke
    i agree with this one, it always looks like it should work
  16. Hank
    Hank
    from Wisconsin
    LMFAO!!!!!!!!
    Just what I needed to read today. Thank you!
  17. losthubcap
    losthubcap
    from Upstate NY
    Its sounds like you need to buy a good 1/2" drill for your tool box !
  18. styleline
    styleline
    from so-hol
    most off them i own en yes the son off a bitch tool to its a combo off them all this is so funny man thanx for posting this one
    cheers
  19. dmikulec
    dmikulec
    Warning: do not read this thread if you work in a quiet environment.
    LOL!
  20. 2OLD2FAST
    2OLD2FAST
    from illinois
    Don't forget the table saw is also good for removing fingers or at least part of the same!! dave
  21. Snickern
    Snickern
    from Norway
    HA HA, this made my day today. cant stop laughing
