Technical Do you think this intake is ok ?
Discussion in 'The Hokey Ass Message Board' started by carolina chevrolet, May 15, 2021.
  1. carolina chevrolet
    carolina chevrolet
    This SBC is in a project 55 Chevy. I was cleaning up the intake and saw a couple of questionable areas. What do you think ? IMG_20210515_194547323.jpg IMG_20210515_194539414.jpg
  2. SBC intakes are easy to come by, why mess with that one.
    jimmy six, 210superair and Deuces like this.
  3. egads
    egads
    If you aren't going to use the choke spring set-up you should be fine. You can get intake gasket's that block the exhaust crossover also.
    Deuces likes this.
  4. harpo1313
    harpo1313
    from wareham,ma
  5. Mr48chev
    I'd have to agree with the consensus, unless there is something so absolutely special about that one that you have to keep it I'd scrap it and get a similar replacement in good shape.
    jimmy six and Deuces like this.
  6. Budget36
    Budget36
    Sure looks to have been wet for awhile. It could still be a usable unit, but not very eye appealing if so.
    Deuces likes this.
  7. Deuces
    Deuces
    Not that one.....:confused:
    210superair likes this.
  8. seb fontana
    seb fontana
    from ct
    Ok if the outside is that condition what is the inside like? Does it even run?
    Tim and squirrel like this.
  9. carolina chevrolet
    carolina chevrolet
    No, it doesn't run at this point. It was missing many parts and I found + rebuilt a carb today for it and was cleaning up the intake when I saw the damage.
    Deuces likes this.
  10. MAD MIKE
    MAD MIKE
    from 94577
    That intake manifold bolt next to the choke pad is not looking good either.
    Unless you are on an extreme budget, pull that intake and see what the ports look like.
    I see rust like that on marine equipment.
    seb fontana, Tim and Deuces like this.
  11. Mike VV
    Mike VV
    from SoCal
    Looks like that engine was ACTUALLY...used as a boat anchor..!
    Mike
    Hnstray, seb fontana, Tim and 2 others like this.
  12. carolina chevrolet
    carolina chevrolet
    The rest of the engine seems to be ok. I'm going to see if I can get the engine running and plan on replacing the intake and carburetor in the near future. IMG_20210515_195025427.jpg
  13. If the bolts holding it on are in the same shape as the intake expect the snap some off removing it.
    Looks like it sat outside for some time.
    How confident are you about the condition of the rest of the engine?
    Deuces likes this.
  14. carolina chevrolet
    carolina chevrolet
    I really have no idea as to the condition of the engine. It's not locked up and the seller said it was supposedly to be in good shape. I don't want to spend a lot of $$$ on it until I hear it run.
    Deuces and egads like this.
  15. 427 sleeper
    427 sleeper
    Judging from the thermostat spacer, it looks like that engine came out of a 60 series grain truck, which leads me to believe there was a rodent's nest of some sort where the intake and bolts are rotted. Either way, when you go to remove the intake, you're in for a real headache. Corrosion from mouse/rat piss is worse than from water. Hope for the best but expect the worst.
  16. Deuces
    Deuces
    I'd replace it with a 4-bbl intake and a quadra boogie carb....
  17. harpo1313
    harpo1313
    from wareham,ma
    Ya, they are cheap enough, besides, it would be nice to get a peek in there before firing it off.
    Deuces likes this.
  18. Looks like a "Krylon rebuild" to me...I'd want to see some of the inside (at least intake off) before I invested any more time or money on it.
    swade41 and Deuces like this.
  19. It would Make a Nice Yard Art......!
    Like you say try to get it running before Putting anymore Money
    into it............!
    Listen to everybody That
    Tell you There are plenty of Small Block
    Chevy's out There.
    Just my 3.5 cents
    Live Learn & Die a Fool
    Deuces likes this.
  20. squirrel
    Fire it up, see how it does....the corrosion on the intake in that area probably won't affect anything other than not being able to use the original choke mechanism. Of course you'll want to swap on a 4bbl carb and intake, once you discover that the engine is OK, or that it's not OK.
    Deuces and VANDENPLAS like this.
  21. Doublepumper
    Doublepumper
    from WA-OR, USA
    It's probably OK. Pretty hard for mickey piss to seep through iron.
    I'd pull it and have a better look.....as I was preparing to slap on a decent four barrel manifold in it's place:D
    Deuces likes this.
  22. Speed Gems
    Speed Gems
    Could be a LG 327 with a steel crank.
    427 sleeper and Deuces like this.
  23. Its not a 327 it you check out the front of the Block
    its eather a 305 or some newer block.
    I could be wrong but thats what it look to me, No 327.!
    Just my 3.5 cents
    Deuces likes this.
  24. carolina chevrolet
    carolina chevrolet
    I think it is indeed a 327, out of a truck of some kind. It's a mid 60's engine. I have already picked out a 4 barrel intake and carb combo but am holding off placing the order until I find out a little more on the condition of the engine. This was a frame off restoration and I wouldn't think they would have set a bad engine back in there but can never be sure what some people will do.
  25. squirrel
    The pad that the numbers are stamped on is wide, like the early blocks...I don't know what you see, but I don't see it.
    timwhit, saltracer219 and Deuces like this.
  26. jimmy six
    jimmy six
    Looks like the stock 2 barrel on the 65 Chevelle 283 we had by the choke heater mount..For what appears to be a nice engine compartment I would not use it. However I would remove the oil fill because it has a PVC fitting attached. This shows its a later intake.
  27. Deuces
    Deuces
    What do the head castings indicate they are???.. I'm not familiar with the markings...
  28. gary macdonald
    gary macdonald
    Itll work as intended but looks may be improved by grinding the choke spring housing down . Your not going to use it , real hotrods have manual chokes with a cable .
    Bill Whitehurst and Deuces like this.
  29. squirrel
    One of mine has an automatic choke, the other has no choke. But I've had some with a manual choke, as well.
    Needs more carburation, to keep us go fast guys happy....
    Deuces and 427 sleeper like this.
