do you think this is strong inough
Discussion in 'The Hokey Ass Message Board' started by cross spring, Feb 27, 2004.
  1. cross spring
    cross spring
    eh guys n gals what do you recon do you think this step up should be strong enough in my tudor? got some more tube to put in the front section cuase im takin out the original centre cross member more pikkys sooon [​IMG]
  2. cross spring
    cross spring
    oohps
  3. DrJ
    DrJ
    What is that, a turn signal switch? [​IMG]
  4. DrJ
    DrJ
    Please, bigger picture with less clutter around it so we can SEE IT!
  5. cross spring
    cross spring
    hows this
  6. cross spring
    cross spring
    oh that sa bit bigger int it
  7. cross spring
    cross spring
    drj not enough time to build and tidy up and take pikkys ,
    cant do that female muti tasking thing [​IMG]
  8. thirtytwo
    thirtytwo
    kinda see what you are trying to do, but i dont thinkthat will add much to the diagonial your still gonna have torsional twist as the mounting points at tube and crossmember are far away from each other and in straight lines back
  9. flt-blk
    flt-blk
    from IL
    All you have accomplished so far is to duplicate the
    origional frame further inboard.
    Tie the tubes into the frame for starters. Not just a
    plate paralell to the frame but a plate perpendicular to
    the frame at full frame height tapered to the tube.
    If you can fit diagonal crssmembers in there you will
    stiffen it up quite a bit.
    TZ
  10. cross spring
    cross spring
    hi flt-blk
    do you mean plate from chassis to the tube to make a kind of big box section ,was thinking of puting some smaller dia. tubing as diaganals from intube to chassis ,
    also somthing i forgot to mention is the car is going to have a basic gage fitted{the rods prime perpuse is to haule my 2 kids and wife to rod runs and stuff}so im hopping that this will stiffen the chassis ,not wanting to build nascar kind of thing but the people who drive on uk`s roads i like a bit of added steel ,cheers for the feed back
    regards keith
  11. Dirty Dug
    Dirty Dug
    Don't be too discouraged. We've all tacked in way more steel than we've left in the car. Start by cutting out everything you've put in, buy a book and start over. Be clear on this, I'm not giving you shit for your effort. I would though if it was the finished product. Good Luck, dirty dug
  12. flt-blk
    flt-blk
    from IL
    I was thinking a couple of gussets like these along the length of the tube.
    It would be even better if you could run some long diagonals from front to back.
