Would the transmission shift cable from a 70s dodge motorhome be to same as the one used in the Dodge A 100 truck?Both seemed to use the dash mounted shifter. Would anyone have a part number or perhaps know where I could find one?
I had 1970 Dodge motorhome ch***is and it had a normal column shift with a cable attached to the bottom end instead of hard linkage. The pick-up cable attached directly to the shifter, I'm ***uming they were different.
Was your motorhome a cl*** B or C which utilizes the existing vehicle cab? The cl*** A have the dash mount shifter. That would be the type of cable I am looking for.
