Technical Dodge Brother In Need
Discussion in 'The Hokey Ass Message Board' started by RamhornJR, Mar 25, 2021.
  1. RamhornJR
    RamhornJR
    RamhornJR in need A.S.A.P. Can any of you Dodge D2 guys know if a 1939 FIRST REVERSE SLIDER GEAR is the same as a 1936 FIRST REVERSE SLIDER and will it work in my stock 36 transmission?
  2. X38
    X38
    Man calm down. You keep asking the same question in multiple threads. In time, someone will answer. This isn't the fire brigade! Patience.
  3. grumpy65
    grumpy65
    It's like 'carpet bombing' for information............
    lothiandon1940 and wraymen like this.
  4. Budget36
    Budget36
    Call Andy Bermbuan or Roberts motor sports, both deal in older Dodge stuff and might know, or know who you can talk to. Both should be found via Google
  5. grumpy65
    grumpy65
    A quick search on the googly machine seems to show 1935 to 1938 as interchangable, but 1939 as a different one.
    Don't take this as gospel. I could be wrong............
  6. Also,,,,it helps having a better worded ***le to a thread .
    More people will read it to start with .
    Tommy
    chryslerfan55 and lothiandon1940 like this.
  7. j hansen
    j hansen
    Try here. @ p15-d24.com
  8. Fortunateson
    Fortunateson
    Which brother? Horace or John? Aren't they both still dead? LOL
    kevinrevin, F-ONE and lothiandon1940 like this.
  9. F-ONE
    F-ONE
    from Alabama
    I think a good hat will solve the issue.
  10. dwollam
    dwollam
    I think you used the term Dodge "Brother" as in you are the brother owning a Dodge. Just for info for all, the name Dodge Brothers was last officially used on Dodge CARS through 1938 by Chrysler out of respect for the 2 brothers. Trucks however continued to say Dodge Brothers under the hood on the tag for several years but no longer on the outside of the vehicles. Chrysler bought Dodge Brothers in 1928.
    This of course has nothing to do with your question! I do believe @grumpy65 is correct in that '39 is a different trans.
    Dave
  11. X38
    X38
    So, for all the A.S.A.P. multi-post huffing and puffing... any feedback?
    lothiandon1940 likes this.
  12. grumpy65
    grumpy65
    ...........and with a snap of his fingers, and a wink of an eye, he vanished just as quickly as he had first appeared. Although many yearned for the day they would see his smiling face again, it was not to be. Some say that his melodious voice can be heard when the breeze pushes lazily through the leaves, but absence can make men believe what is not really there........:rolleyes:
  13. RamhornJR
    RamhornJR
    To answer your question X38 ,no luck. It’s all good had a friend doing a pick in a small NE town, the old boy had a box of 39 Dodge parts. Didn’t know if I should buy theme or not. Don’t need more parts on the shelf if they don’t work for me. Then it hit me turn to HAMB! Knew I had enough threads to get on the board but couldn’t get a thread through, so I tried the Beginners board. Success. Then I asked for help, pprather worked some magic and my questions got posted on the Hokey. Still trying to figure things out on my end, BAM...My threads when through! So there you go, four threads. Send the Fire Brigade! One hell of a way to hit the big board, not even a member and a Dodge guy on top of it. My friend has moved on with a bunch of Ford parts and the old farmer still has his box of 39 Dodge parts. P.S love the poem, Grumpy.
  14. X38
    X38
    Okay.
    You don't need anything other than joining to post on the board. 10 post minimum is for contacting people via conversations in the cl***ifieds (the only way you can respond in the cl***ifieds.)
    And next time, the Chicken Little routine doesn't get answers any faster, but it may rub people the wrong way.;)
    grumpy65 and Desoto291Hemi like this.
  15. RamhornJR
    RamhornJR
    Not trying to wright my wrongs, Totally screwed up! It’s not like, call Bob Drake and have everything delivered to my front door the next day....but believe me I would if l could! Thanks for burying the hatchet.
