Dodge flathead I.D. help..
Discussion in 'The Hokey Ass Message Board' started by realgonekatt, Dec 20, 2008.
  1. realgonekatt
    realgonekatt
    So, I have this dodge flathead that came with an old project p/u (in the bed) and not original to the truck. Well, the truck is long gone and now I have the old plymouth... I wanna use the dodge mill for my "hot" setup as it looks real swell inside. However,
    I dont know if its a 218" or 230"?
    Head casting: 1120803-5
    Block casting: H19729-24
    vin? on block at top: t112*I87672*
    As always, any help is appreciated,
    ___Bryan
  2. Thumper
    Thumper
  3. ,,,,,,,pull the head & measure, you're gonna get into it anyway..
  4. R Pope
    R Pope
    Most Chrysler sixes have a vertical pad on the right front corner of the block with model and cubic inches stamped in, at least Canadian ones do.
  5. ChryslerRodder
    ChryslerRodder
  6. plym_46
    plym_46
    from central NY
    measure the head either 23.5 or 25, post the number in the boss on the block above the generator, just below the head. P = Plymouth, C = Chrysler, S= Desoto, D= Dodge, T = Truck, IND= industrial, Also, there is a pipe plug in the head above #6 cylinder, pull the plug, insert a 19 inch piece of stiff wire, and run the engine through a rotation, this will allow you to measure the stroke, for 23 inch heads, 4 3/8 = 217.8 cu in, 4 5/8 = 230 cu in. bore is the same. Opps just saw the "T" number ist a truck block, do the stroke measurement and you will know if is the 218 or 230.
    Follow the link in the above post and post the number on the truck forum Pilothouse.com and coupe fellows there will be able to tell you year of maufacture. The truck serial umber should be on one of the a pillars.
    That number will thell where and when the truck was manufactured
    Here is a pic of the engine number. If you have a long block, its likely a 251 (although it could be a Canadian 230, as they built only 25 inch engines.
  7. Archie
    Archie
    This is from a 1942-47 wc (1/2ton) or/some wd (3/4) ton
    Its a 218 but can be re-built into a 230. I have Charlie from Rustyhope.com rebuilding my engines, he would be able to help.
    http://www.rustyhope.com/index.html
    Archie
