dodge guys...40 dodge rodding question
Discussion in 'The Hokey Ass Message Board' started by Lono, Apr 10, 2009.
  1. Lono
    Lono
    I'm still looking at my 40 dodge mordoor and haven't got my act together. I'm playing with selling it or swapping it for something that can put a real fire under my ***. I've got as far as trying to motivate myself in photochop but even thats not working.
    I was wondering if you dodge guys know if there's a cheap way to quickly drop it 3- 4 inches up front. I've got a 318 lined up for it and an auto.
    Is there a Dodge forum out there I can find?
  2. 73RR
    73RR
    try asking over at www.p15-d24.com but don't tell them everything...they aren't rodders like most folks are here, they stay closer to stock bodies.
  3. plym_46
    plym_46
    from central NY
    No we don't!!! Come on over. Several guys fitting v8 and folling around with sawzalls.
  4. Retro Jim
    Retro Jim
    Put a 440-6 pack under that hood and if that doesn't lite your fire nothing will !
  5. nmbuellist
    nmbuellist
    front is easy--did my 39 this way---on your lower a-arm you grind off the rivits holding the plate that the coil spring sets on--it is on the upper part off the a-arm---then move it to the lower part of the a-arm---bolt it on then and go ahead and weld it for extra---this gives you that 3 inches---cost is six new nuts and bolts per side----this tip was in an old Tex Smith book from twenty years ago
  6. dodge39
    dodge39
    Hi mate. would this work on my 39 dodge four door.Would save having spring work done.?Could you send me a PM or email with the basics.First time rodder.Hows this go with certification on the car.?do you have to have a weld ticket to comply because your playing with the suspention????
