Dodge Intake
Discussion in 'The Hokey Ass Message Board' started by Ratbug, Jun 17, 2011.
  1. Ratbug
    Ratbug
    from Yardley Pa
    I am building a '91 360 engine for my '32 Plymouth PB. I have an intake that's been sitting in my shop for about 20 years and I want to use it to top off the build. I have checked the casting numbers and can't find them referenced in any of the books I have, so I'm asking for help from the HAMB.
    It is a cast iron dual plane with rectangular ports and the casting number 4100340-1. All the bolt holes and ports line up, (I checked using the gasket) the only issue I can see is an upside down U in the center of each head that is not covered by the intake.I was told by the gentleman who gave it to me that it was off of a police interceptor. Any help from the Mopar crew would be appreciated.
  2. Ratbug
    Ratbug
    from Yardley Pa
    Maybe these pictures will work
  3. brad2v
    brad2v
    My casting # reference is at home, but don't worry about the exposed opening, just the way small block Mopars are.
  4. das858
    das858
    You might want to ask on a- bodies only, those guys know their casting numbers.
  5. R Pope
    R Pope
    A standard Thermoquad hirise, probably off a 360. Good manifold, I have three of them on various Dodges.
  6. remember theres a diffrence from the LA motor to the Magnum motor
  7. brad2v
    brad2v
    Correct, and the '91 motor is an LA, as is that intake with the 7 digit cast #
  8. correct been running them for years like that. what stricks me is that a 360 LA intake should not fit a Magnum 360.
  9. pcterm2
    pcterm2
  10. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    The magnums first showed up in 92 I believe.
  11. 50dodge4x4
    50dodge4x4
    The LA intake will work on the Magnum engine if you modify the mounting bolt holes. The LA intakes the bolts went into the head at a 90 degree angle to the intake surface, on the Magnum engines, the intake bolts mount into the head at a 90 degree angle to the top of the block. The holes and ports match up, just the angles are different.
    That is the later model small block intake 78 & newer, because the thermostate housing is not centered on the intake like the older intakes (72-77). You will need to use the newer stat and gasket because they are smaller (I think) then the older ones.
    Gene
  12. Ratbug
    Ratbug
    from Yardley Pa
    Thank you for all your help
