Anyone know how to remove and replace the seal on the oil dipstick on a 225 6 cyl dodge? Got oil going everywhere!!
wrong page, this is for Intro's. , need to go to the main page of the H.A.M.B. Good Luck ! firstnomad
Do take time to introduce yourself. As to your oil leak problem, are you sure it's coming out around the dipstick? It could be leaking around the front crankshaft seal and blowing back onto the engine as you go down the road. If it's coming out around the dipstick, either you've got a clogged PCV valve, or the rings are worn to the point that you're getting a lot of blow-by allowing it to build up pressure in the crankcase.
