DOES 55 hydromatic trans have tailshaft seal??
Discussion in 'The Hokey Ass Message Board' started by 55starchief, Jun 26, 2013.
  1. 55starchief
    55starchief
    from New York
    Id like to fill my tranny up and start my car but still have the driveshaft off. Will i lose all my fluid thruogh the propeller shaft end? I know more modern trans have a tailshaft seal between the spline and driveshaft, does a 1955 hydromatic trans have the same?
  2. uncledon529@bellsouth.net
    from florida
    There is only the end seal so you will lose the fluid. I just changed it and the bushing last week in my 56 Star Chief. Don
  3. I have a '54 and a '55 hydromatic. Both were bolted to the engine, but neither had the yoke or driveshaft attached. Both were full of fluid until I dropped the pan and drained them...
    :confused:
  4. Bobert
    Bobert
    You must have been lucky? My temporary patch. Piece of correct sized pvc pipe and a plug.
  5. Obviously a misunderstanding then. It looks like the tailshaft has been removed from your transmission?
  6. 55starchief
    55starchief
    from New York
    speedy,
    i had the same thing, when dropped the driveshaft nothing came out. but after talking to guys at work, i just got lucky or the tranny was already low. looks like bobert's pvc goes around the tailshaft then is plugged on the end.
    bobert,
    am i correct? thanks for the help.
  7. Atwater Mike
    Atwater Mike
    You are correct...at least, that's the way I do it. (and it works!) No need to buy an extra slip yoke. ($$$)
  8. 55starchief
    55starchief
    from New York
    awesome thanks guys!
  9. d2_willys
    d2_willys
    from Kansas
    get a driveshaft yoke and use it.
  10. Bobert
    Bobert
    Yup that's where it goes. Replaces the yoke in size. I used that plug cause it was on hand. Could have used a pvc cap. The yoke was already on the u-joint. I some times do stuff backwards.
  11. 55starchief
    55starchief
    from New York
    Thanks for the help
  12. Well I guess I got lucky twice then, and learned something new.
