Technical does a 36 ford use a curved rear spring?
Discussion in 'The Hokey Ass Message Board' started by nobby, Mar 17, 2024.
  1. nobby
    nobby
    planning on switching the rear crossmember from a 37 to a 36 to lower it some,
    looking at the 36 crossmember, does it use the same 37-40 rear spring
    have the 36 rear radius rods.
    hmm
    is it just 33 and 34 that uses a curved spring 35 36 37 38 39 all the same
    even though the 36 crossmember is different
    OR
    considering the crossmember from this chassis was bolted in
    is it incorrect for a 36 chassis - it being lower
    and could be from an earlier chassis
  2. Fordors
    Fordors
    Curved spring only on the 1932-‘34 cars.
    bschwoeble likes this.
  3. nobby
    nobby
    do the 35 and 36 fords use a flatter rear crossmember than 37 38 39 and 40?
  4. Deuce Lover
    Deuce Lover
    NO.The front yes
  5. nobby
    nobby
    nobby's 1936 ford pickup project 10 March 2024 (youtube.com)
    so that rust covered rear cross member in that 36 frame isnt a 36..
    this might be what is foxing me
    as it did have 35 36 radius rods and the 36 axle...
    this rear crossmember was bolted in - not stock rivets
    so it is a 33 34 rear x member?
  6. alchemy
    alchemy
    A 33-34 crossmember will have the center portion curved to hold the curved spring.
  7. nobby
    nobby
    Is a 36 the same as a 37
