Folks Of Interest Does a property owner " OWN" an " abandoned " car?
Discussion in 'The Hokey Ass Message Board' started by King ford, Sep 2, 2020.
  1. 37 caddy
    37 caddy
    from PEI Canada
    Know any one who has a big crane,they could lift it straight up?.and set it down on a trailer.That would be the least intrusive way. Harvey
    49ratfink and LWEL9226 like this.
  2. GTS225
    GTS225
    Maybe a "log roll" exit for the truck?
    Roger
  3. BamaMav
    BamaMav
    from Berry, AL
    With the new info, I'd get the other guy involved in the move. Ask him how he'd rather get it out with the least damage to his property. You might even go as far as buying some sod you could put out after the truck is moved.
  4. Bearing Burner
    Bearing Burner
    from W. MA
    Ever hear the expression posession is 90% of the law
  5. F-ONE
    F-ONE
    from Alabama
    Easily done! Very easily done if you have anchors.
    No anchors? Plant some. Three heavy duty T posts driven in at an angle against the pull. Position the three where the chain pulls against the three.
    Get the truck up and you can slide the flats on soapy (dish soap) soaked boards or plywood. Slide the truck out on the wood. Worse come to worse you can slide wood on wood.
    This is how heavy AC units and House trailers are slid around.....
    On wood and soap.
  6. Atwater Mike
    Atwater Mike
    Draw up a fake 'will'.
    Where there's a will, there's a way. And an edit:
    "Possession is nine POINTS of the law." (1650 excerpt)
  7. Apache Albert
    Apache Albert
    Done this to 5-ton industrial units. Surprising what a lil dawn or washing soap can slick.
  8. LWEL9226
    LWEL9226
    from So. Oregon
    Rent a boom truck.... Lift it over the fence or out to the asphalt driveway and done....
    LynnW
  9. 5window
    5window
    Yeah, maybe, but you probably spent a lot of time lying abandoned in a field, just like this old car! :)
    clunker and 56don like this.
  10. clunker
    clunker
    from Boston MA
    Absolutely. That I did. Despite my best efforts, unfortunately. I got turned down more often
    than a hospital bed.
    Apache Albert and 5window like this.
