Does anyone here warm up their brake line befor bending or flaring???
Discussion in 'The Hokey Ass Message Board' started by tlmartin84, Jun 27, 2012.
  1. Kiwi 4d
    Kiwi 4d
    No never. Just use the nicoop tube , mix of copper and nickel. Slightly softer and forms beautifully, yet still rigid enough to meet safety regs.
    hotdamn and warhorseracing like this.
  2. A Boner
    A Boner
    Try some ni/copp brakelines...you will probably never use any other kind!
    hotdamn, Elcohaulic and David Gersic like this.
  3. clem
    clem
    It heats up in both of the processes asked about, that is probably enough heat...........
    I’m curious as to what a ‘buggy’ is that OP refers to.
  4. southcross2631
    southcross2631
    Was making the brake lines on my 65 Comet . Just use NiCop brake line . Does 90 degrees and 60 percent humidity count ? That how hot it was today and the line flared and bent just like it always does.
    No issues.
    Truckdoctor Andy likes this.
  5. The easiest way to flare brake lines is to spend the extra money (yeah, I know it’s expensive) and buy the hydraulic line flaring tool. Mine works perfectly on NiCop and steel.
    continentaljohn likes this.
  6. norms30a
    norms30a
    Want perfect bends and flared ends, I put a little oil on the tubing and it slides on the bender perfectly, same when double flaring.
    bill gruendeman and WB69 like this.
  7. WB69
    WB69
    from Kansas
    Never do the heat. Also, have the SK set and use a little oil like said above.
    norms30a and Elcohaulic like this.
  8. You may find this hard to believe, but when I was bending conduit on jobs you had to correct for ambient temps. You'd get more 'spring back' the colder it was. On small tubing though I wouldn't apply much heat. Maybe lay it over a light...
    Elcohaulic likes this.
  9. 57 Fargo
    57 Fargo
    Use brake fluid on brake lines, anything petroleum based is bad in brakes
    norms30a and J. A. Miller like this.
  10. southcross2631
    southcross2631
    I hope I don't die. I used my $ 8.00 Harbor freight double flaring tool .
    It does the job and I have built many cars using the same tool.
  11. Elcohaulic
    Elcohaulic
    Never did this but I'm going to try it..
  12. I believe it has more to do with the user than the tool. The mobile tool salesman want the young kids to believe it’s the tool that makes the mechanic, time and experience has shown me that it’s the mechanic that makes the tool.
    rusty valley and bill gruendeman like this.
  13. billfunk29
    billfunk29
    from Minnesota
    I once had a cheap double flare tool where the double flare ****on was not on center. The counter sink and pin were not concentric. How could that even happen?? A lot of s**** tubing before I figured it out. Now, I look at cheap tools as a parts kit. Keep what works and rebuild the rest.
  14. dalesnyder
    dalesnyder
    I use a spritz of wd40 on the anvil and die when flaring also. Never tried it while bending. I would think it would help if using a bender that did not have roller bearings.
  15. norms30a
    norms30a
  16. bobss396
    bobss396
    That's what SHE said....
  17. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Nope. not even using a cheaper amazon special flaring tool. clean the ends good, get the clamp tight let the tool do its job.
  18. 54vicky
    54vicky
    if you need to heat the line then eat a hell of a lot more spinach.
  19. rusty valley
    rusty valley
    no heat, ever, but i do take a file and slightly bevel the outside edge of the tube. this helps the tube start to roll over in the die for the double flare. not really a full bevel, just dress the edge a bit. it helps
  20. The Imperial flaring set I bought years ago actually recommended that in the instruction sheet.
  21. hotdamn
    hotdamn
    Nicopp makes life a great deal easier, however one thing I would caution you on,
    when using Nicopp lines be careful about tight bends next to the fittings.
    I did this on my wifes Model A and after about a week or so the brakes bled out from a tiny hole that formed where the fitting was hitting against the line.
    I ran another line and have had zero problems since, that was over a year ago.
