Does anyone know the color codes for Scotch Brite pads?
Discussion in 'The Hokey Ass Message Board' started by Groucho, Nov 10, 2010.
  1. Co****/medium/fine? And do those colors also apply to floor machine pads? Thanks
  2. 49ratfink
    49ratfink
    I'm thinking maroon is course, gray is fine.
    is there a medium? I've never bought any if there is.
  3. Whaddabout green? And RED.....
  4. Deuce3wCpe
    Deuce3wCpe
    from New Jersey
    in the old machine shop I worked in (E**ON) I remember we also had green and white (white was super fine I think). We also had brown pads that were stiffer and fairly co****....I remember one of the old Germans there used to call them "Bear-Tex" pads.....
  5. Master of None
    Master of None
    Red=scuffing primer areas that are hard to reach
    Gray=scuffing clear coated parts that are hard to reach (wheel lips on collision jobs)
    white=ultra fine (I've never had a use for them yet)
    Not sure how they convert to floor polishing, haven't done that yet either.
  6. hotroddon
    hotroddon
  7. Stu D Baker
    Stu D Baker
    from Illinois
    When I had my floor scrubber, I used black pads. They were the co**** ones, because I was scrubbing overspray from floor tile in my spray booth.
  8. allstarderrick
    allstarderrick
    The white ones work good for cleaning overspray off of gl*** and chrome. Otherwise stick to the co**** red and fine gray.
  9. stealthcruiser
    stealthcruiser
    The most agressive, of the "normally used" Scotchbrite pads, is the brown one........................Can't help on the florr scrubber part, as I gave up janitorial work LONG ago.....
  10. ADReese
    ADReese
    from spokane
    In 3M:
    Red is about 320- 400 grit
    Grey is about 600-800 grit
    White is about 1000
  11. I know that is what 3M says, but I don't buy it. Put a new grey scotch brite in one hand and a new piece of 600 sandpaper and tell me they are even close. To me a grey pad feels more like a 280-320.
  12. rustrustler
    rustrustler
    for floor machines lighter is softer darker is co****r. Mike
  13. loveoftiki
    loveoftiki
    from Livonia,Mi
    Hey guys I am a 3M Rep here in Detroit. Thanks for the interest in our produsts. Here's how it breaks down
    7445 (gold) =clear blend scuff pad= prep for blends, good for metallics and pearls, easy buff back, clear prep adhesion
    7446 (maroon)= primer prep scuff = prepping e-coat on new panels,door jambs, underhhod, provides good primer adhesion
    7448 (grey)= use for prep of colorcoat areas and easy blends ( i.e. non metallic, pearl ) provides optimum color prep adhesion
    I hope this helps- you can also check your paint companies P sheets to see what they reccomend. Also something to remember is with the new waterbased paints you should go up with your abrasive grades ( if you were sanding primer with 400 move up to 500 - 600 )
    Thanks again for using 3M
  14. Jimmy2s83
    Jimmy2s83
    from Indiana
    I use the 2" and 3" scotchbrite discs and the colors to girt are as follows.
    Brown- Co**** (80-100grit)
    Red- Medium (180-220grit)
    Grey- Fine (280-320 grit)
    Blue- Very Fine. (400-600 grit)
  15. Bad Bob
    Bad Bob
    from O.C. Baby
    Brown-left hand
    Green-right hand
  16. RidgeRunner
    RidgeRunner
    from Western MA
    FWIW, Sheet from Mercer Abrasives [made in England] that came with scuff pads I picked up from a swap meet vendor says:
    Light Green - Non abrasive for scouring and general maint
    White - Non abrasive for polishing and light cleaning
    Grey - Ultra fine silicone carbide abrasive for fine hand cleaning and finishing
    Maroon - Very fine aluminum oxide for basic cleaning and finishing
    Green - Fine aluminum oxide for removing rust or corrosion
    Black - Medium aluminum oxide for heavy duty cleaning or fast action finishing
    Tan - Co**** aluminum oxide for stainless steel aluminum and for stripping
    Ed
  17. 41woodie
    41woodie
    Red is for everyday dishes, green for pots & pans.......on a more serious note the green ones will scratch gl*** if used agressively, for real
  18. schwerko
    schwerko
    from bristol ct
    I found maroon is best for taking a scratch out of flat clearcoat, still not perfect... Gray will give it sheen, green will leave scratches, is what I found.
  19. CutawayAl
    CutawayAl
    from MI
    Just like sdandpaper, the product dulls with use. But I agree, it starts ourt co****r than they claim. Although it shortens the useful life of the product, sometimes I dull Scotch-Brite on a piece of steel plate before using it.
  20. mj40's
    mj40's
    And the red is used where? Ouch! :D
  21. Bert Kollar
    Bert Kollar
    I know green scratches gl***. I use blue for general cleaning
  22. brucer
    brucer
    from western ky
    i use to use the white pads and wd40 to polish acrylic duck calls..
  23. stealthcruiser
    stealthcruiser
    "Acrylic ducks"?????
    Similar to the pink plastic Flamingos, that go in your yard???:eek::eek::D
