does anyone know what year this hemi is?
Discussion in 'The Hokey Ass Message Board' started by goodguyinblack, Oct 13, 2011.
  1. goodguyinblack
    goodguyinblack
    from el lay
    doesn't 51-53 have two waterpumps? thank you
  2. metalman
    metalman
    Might want to post an intro before jumping on here, they will jump you for it.
    As far as I know all Hemi's have one pump. Your pics don't show it but is your bellhousing part of the block? If it is the you do have an the early Hemi.
  3. squirrel
    Also, the numbers stamped on the top, front of the block will tell you what you need to know.
  4. moparmonkey
    moparmonkey
    from NorCal
    Should be just one water pump for all the hemi's.
    However, that engine has a "wet" intake, and no water crossover ports at the front of the heads. That would lead me to believe that the heads are the '51-'53 variety, since later heads had water ports in the front for the crossover. But, the engine could still be something other than '51-53. Still, if I were a betting man I'd say it was a '51-53 331, or possibly a slightly later truck engine.
    The use code stamped on the rail between the valley cover and the water pump should tell you all you need to know, as squirrel already pointed out.
