Is it possible to bolt on a 1950 ford passanger car steering wheel to a 1950 ford f1 pickup? I would like to do this, but I am not sure if it requires machining. Any help would be appreciated. Shaun
Don't know the answer to that but ! I'm running 50 car column in my 28 coupe ! Extremely simple column , if it want fit , I think light machining should fix you up quick ! Do you already have everything ? I put keyway in shaft , and made aluminum wheeladapter w/keyway ! The 50 column is splined , they might fit !
