Hot Rods Does anyone really do offset cranks anymore?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Feb 20, 2025.
  1. Roothawg
    Roothawg
    If you turn it, do you have to heat treat it or anything?
    Tickety Boo likes this.
  2. saltflats
    saltflats
    from Missouri
    Mile High Cranks can nitride the crank after turning down the mains. That is what I will have done.
    Tickety Boo and Roothawg like this.
  3. seb fontana
    seb fontana
    from ct
    Back maybe early 70's I called Gapp&Rauch when I found out they were putting Y block 292 forged cranks in the Windsor with grind/machine work. I had a crank; would have been a 1k $ bill.
    Roothawg likes this.
  4. Fordors
    Fordors
    It will have been heat treated throughout if it was a forging, but if it was a Hi-Perf crank, like a high horse 396 for example, it may have been Tufftrided. Tufftride is only a surface treatment a few .001’s deep that enhances the ability to reduce scuffing and abrasion.
  5. saltflats
    saltflats
    from Missouri
    We ran a bunch of the 350 Chevy cranks offset ground and used small journal 327 rods in the sprint car.
    Tickety Boo and mad mikey like this.
  6. Roothawg
    Roothawg
    The stock Caddy rod journal is 2.250". It had a 6.625 " length.
    A BBC rod is 2.200" and 6.135". That's what most guys retrofit in the 390.
    If you run the longer BBC 7.250" rod, you can use a standard SBC piston.
    The Pontiac 455 Rod is the same diameter rod but it is about .125" too wide.
    Your mileage may vary.
    warbird1, saltflats and 2devilles like this.
  7. saltflats
    saltflats
    from Missouri
    I have a good friend that was racing in the Hemi Challenge series. He said they were running Honda rod journal size in the 426.
    seb fontana, Tickety Boo and Roothawg like this.
  8. Adriatic Machine
    Adriatic Machine
    This was done around 10 years ago. 425 Nailhead stroked to 450ci. Lots of port work to facilitate breathing. Crank was not welded, only offset ground to accommodate SBC rods. She goes. @gary terhaar
    RodStRace, Baumi, 3blapcam and 4 others like this.
  9. 3blapcam
    3blapcam
    Bringing this back to the top...
    @saltflats... have you had your crankwork done at Mile High yet? I had him grind another .010" off my stock 8ba crank so that I could use it again. I think I paid more to have that work done (I recall it being $280 two years ago) than the crank itself is worth! Either way, the work was done well, and I wasn't in a hurry, so I'm not complaining. I was on the fence about putting that engine back together again, but I did, and I'm thankful. I had not used him before, but it's a 3hr (1 way) drive for me. I was told my only other option was Albuquerque... which is also 3hrs away.
    I have a Merc crank that is at the end of its life - 0.040"/0.040" and grooved... so this topic has me interested. I think I will call them and see what it'll cost to have it welded & cut. I either spend the money on the crank or toss it in the trash... Although I think I would rather have an original modified crank versus a Chinese reproduction.
    3blap.
    tractorguy likes this.
  10. saltflats
    saltflats
    from Missouri
    No I haven't yet. That is a project that hasn't been a high priority.
