Technical Does anyone still make sparkplugs with screw-off tips?
Discussion in 'The Hokey Ass Message Board' started by willys36, Apr 18, 2017.
  1. willys36
    willys36
    I have sparkplug wires (pretty new) that have plug connectors that slip on the threaded tip of a plug. Not intended to slip on the bulb tip that is standard nowadays. Last time I bought plugs, Autolites, they had the old style screw-off bulb tip. I tried to buy a set recently and every manufacturer carried by my auto parts store had permanently attached bulbs, no screw stud. Does anyone still make the old style? I hate 'new and improved' stuff. Guess I am getting old.
  2. Engine man
    Engine man
    from Wisconsin
  3. 46stude
    46stude
    I have a set of Bosch Platinum's in my '72 Cheyenne's 350 that have those style tips. Might look in to a set of those, unless they've "upgraded" recently.
    jeffd1988 likes this.
  4. Champion does and I believe AC/Delco. probably depends on the plug.
  5. dreracecar
    dreracecar
    from so-cal
    ask for plugs for a VW , they still use a stud post
  6. Ngk still does. Use them in the Flathead and the Studebaker (same part number)
    Atwater Mike likes this.
  7. willys36
    willys36
    Need Autolite 45 or equivalent for Ford 390 FE.
  8. Truck64
    Truck64
    from Ioway
    Some say NGK AP5FS is a good cross for Autolite 45, check your application and whether this will work for you. This pic shows a plug without a tapered seat, so I dunno, wish they didn't use one stock photo for every plug.
  9. willys36
    willys36
    Thanx. My engine uses a gasket plug like that, not a tapered seat so that looks like what I want.
  10. Truck64
    Truck64
    from Ioway
    Pretty sure that plug has a tapered seat in real life, as does Autolite 45?
  11. Atwater Mike
    Atwater Mike
    NGK had a plant next door to the BMW school in Culver City, CA. If they are still there, knowledgeable staff will help you. They can cross check any known spark plug manufacturer, and have listings for all makes & models.
    Plus, a long history of racing applications. Heat range and various electrode metals, etc.
    Impressive. Progressive. (in the positive vein)
  12. jeffd1988
    jeffd1988
    This is true. I recently bought some plugs for a off topic vw Bosch brand and they have the screw top. Look into Bosch I guess for sure they may have em
    Sent from my Z981 using The H.A.M.B. mobile app
  13. Kan Kustom
    Kan Kustom
    I didn't realize the tips don't screw off anymore. Seems like things change and go away faster these days since all the electronic have taken over.
  14. Jalopy Joker
    Jalopy Joker
    45 no longer equals a heat range, only means a "family" - reading modern plugs not the same as in the day - take a look at ngk.com
  15. Sheep Dip
    Sheep Dip
    from Central Ca
    If you need br*** nuts for those I believe the NGK's take a M4-.07 pitch
  16. willys36
    willys36
    you are correct those are tapered. I am a Chrysler hemi man, this is my first deviation into Phord stuff!!
  17. according to the NGK website , an autolite 45 crosses to WR5..stock # 2438 as oldtimer said
    if you look at the picture it has a screw on tip
  18. willys36
    willys36
    NGK seems to be my best bet. Thanx for the input.
  19. Jalopy Joker
    Jalopy Joker
    also, can usually find NOS spark plugs on eBay - BF42 a common for 390, and others - but, need to locate info for your specific motor
  20. NGK have the same plug under two different part numbers: one with solid tip, the other without. When I was selling them, I would either look at both, or remember common ones.
    But, I had (still have) the NGK catalogue, not a computer screen...
    Cosmo
  21. willys36
    willys36
    Pistons just need to go up and down under their own power (with a little gasoline help!)
  22. Jalopy Joker
    Jalopy Joker
    did not know that motors were so simplistic
  23. Atwater Mike
    Atwater Mike
    Yeah...they run on 'instinct'.:p
  24. willys36
    willys36
    that's all
    I need it to do; start easily and idle. Zero performance requirements. It is all about the look.
  25. Bleach
    Bleach
    I thought you meant if anyone makes spark plugs with screwed up tips.
  26. willys36
    willys36
    Nah, if I wanted that, I am more than qualified to do it myself.
    Bomb likes this.
