My 61 Ford just got NOS headlight chrome rings ...the old ones just disintegrated... When I got the new ones I could see why.. no paint or rustproofing on the backs i want to protect these ones and like to know if I should prime ..[paint then rustproof or will rustproofing all I need I use the undercoat spray can dry type from rust-ileum.. Thanks for the info..DANiel
If they are chrome rings, they should have the same plating on the whole part, just not as polished. You can't dip a part into a chrome tank without the liquid covering the whole thing. That said, I'd still clean the backside very thoroughly with lacquer thinner, then prime and paint with a spraycan of Krylon or Rustoleum. No nead for thick undercoating on a headlight ring.
Yes your right this is the secound time I bout NOS and the chrome plateing was poorly applied! I called my body shop man and he recommend to have them rechromed or if I wanted to try sanding the backs and applying self etching primer then ,, paint them (which I will with dull aluminumn) so far I used th e self etching primer and it sure looks like it will work becuase some of the paint went on my hand and go jo would not take it off! ...DANiel
