Technical Does Steel Age?
Discussion in 'The Hokey Ass Message Board' started by Boneyard51, Jan 17, 2019.
  1. Boneyard51
    Boneyard51
    For the umphteenth time I read , here on the HAMB, about the age of steel. I read “ do you really want 85 year old wheels on your car” I understand that steel can rust and wheels and other things can become weak due to pitting and rust through. But does just “ age” effect steel/iron? Just wondering.
    Bones
    scrap metal 48 and BigO like this.
  2. squirrel
    If the wheels had been used for all of 85 years, they might get fatigued....and things like steel valve springs on race cars are replaced on a regular basis because they get worn out.
    But it has more to do with cycles of use, than it does with age.
    I prefer using old steel, whenever I can.
    deucemac, kbgreen, Hnstray and 2 others like this.
  3. scotts52
    scotts52
    Does it age? Yes, along with everything else. I think the real issue is stress. Wheels take a lot of stress during driving and the longer they've been exposed to stress the weaker they become.
  4. I don't honestly know, but besides the obvious (rust, stress damage, corrosion) I think some people are paranoid. Rivets and bolt holes can loosen up over time, and repeated stress causes fractures, but old steel (if it's in good shape) is the best steel. Old steel sounds more solid when you knock on it, feels better in your hands, heck it even smells different when you cut it.
  5. nugget32
    nugget32
    If a wheel is pushed beyond its "yield strength" numerous times is is going down the road to failure as in breaking.
    Sent from my VS500 using The H.A.M.B. mobile app
    VANDENPLAS, Boneyard51 and Elcohaulic like this.
  6. s55mercury66
    s55mercury66
    from SW Wyoming
    If they are worried about the wheels, they should really be worried about the sheet metal they are riding around in. Why, it could completely disintegrate at highway speed some day.
    Boneyard51 likes this.
  7. Chili Phil
    Chili Phil
    Does a kitchen sink?
  8. oldiron 440
    oldiron 440
    I've done work on post war cars that have had metal fatigue in the sheet metal, that is after welding it would split or crack. I've never had trouble with steel but I know others talk about it.
    lothiandon1940 and Boneyard51 like this.
  9. warhorseracing
    warhorseracing
    from cameron wv
    Did you ever notice the cracks in fenders on a lot of pre 1940 vehicles? That is a stress point at which the steel failed due to constant flexing. Kind of like bending a steel wire back and forth to break it when you have no tools to do so. Those are some exaggerated examples of steel failure under stress. With design improvements the cracking fenders went away. Became not a problem not so much as improvements to the steel but design changes. The answer to your actual question is yes but can be delayed indefinitely with proper maintenance (protective coatings or paint) and original design (eliminated fender cracks).
    Black_Sheep, pitman and Boneyard51 like this.
  10. Blues4U
    Blues4U
    from So Cal
    Anything will "age", or change with time. There's more to the story, depending on the forces acting on the material. For steel, just plain steel left alone in a dry environment, the time till any aging degrades the structural integrity is far beyond human life times. As Squirrel posted above, this is really about cycles of elastic deformation, where the steel elastically deforms under stress then returns to it's former shape when the stress is removed. The amount of and frequency of deformation effects the service life of the part. Then there is also erosion and corrosion that will affect the service life of the material.
    "Old" steel is probably better because of the original structure of the metal, not because of any "aging".
  11. Metal fatigue is a well do***ented material science phenomenon. It is not solely time dependent. All metals have a fatigue life limit, and that is mostly determined by the number and magnitude of the stress/load cycles seen over time.......the higher the stress cycles (and rate of cycling), the shorter the life will be. Each ally will have a unique fatigue limit. Stress concentrations, such as rivet holes and sharp angles, are typical locations for fatigue crack initiation......and total failure of the part. Crack propagation rate is a function of material alloy and stress levels. Also, as noted above, corrosion can significantly advance fatigue failure, particularly in stainless steel.
  13. That’s one heck of a big hot pot !!
    How many gallons of steel does it hold?
    I do work at an aluminum foundry and they routinely fill 30,000 litre hotspots of aluminum and cart them around to there smelting lines with a 50k forklift neat to watch. Can keep the aluminum molten for 3 days with a gas head in through a hole in the lid and a mixer going. Not that they do that but if a failure happens and they can’t tap the hotpot right away at least it’s not a 30,000 litre **** up!!
  14. 1946caddy
    1946caddy
    from washington
    I will gladly pick up any 32 or 36 three window Fords that are probably suspect due to their age and I won't charge you a anything for my trouble. :cool:
  15. krylon32
    krylon32
    from Nebraska
    So are you saying it's dangerous to be using these old parts such as axles, bones, suspension in general and old wheels?
  16. Torana68
    Torana68
    from Australia
    Yes, and no, depends on what sort of life they have had, I crack test old stuff that might kill me, everything old that is a safety issue should be examined closely. This is fatigue and collision damage nothing to do with age as above have said.
  17. Most auto parts designed before 1970 have sufficiently high margins of safety that they will have, for all intents and purposes, infinite fatigue life. BUT.....stress risers, such as axle fillets, gear teeth roots, and frame corners, were not well understood by the designers, and are found to crack as high use occurs. These can be easily inspected with dye penetrant to determine if cracks exist.
    Atwater Mike and lothiandon1940 like this.
  18. BigO
    BigO
    That's a wonderful question !
    bct likes this.
  19. Boneyard51
    Boneyard51
    Guys I understand metal fatigue and stress factors that limit the useful life of a metal object. I guess I understand the basics, not sure I can determine it perfectly everytime by looking at a part. Sometimes you just have to guess, or we would have to replace everything in our old cars. Parts on my car are over fifty years old, some of the other guys on here have cars pushing 90 years .
    Seems odd that people worry about 85 year old wheels that were on a relatively light car that probably Only went 75 mph once in its entire 40,000 miles life, built with good American steel. But have no trouble getting into a car that has 250,000 miles and 80% of them we’re probably over 75 mph, but are 10 year old and made out of forgien steel.
    Myself I’d be more confident in the old American made wheels. Just wondering about just how much age is a factor?
    Bones
    clem and scrap metal 48 like this.
  20. BJR
    BJR
    Only when the foundation is bad.:D
  21. Myself I’d be more confident in the old American made wheels. Just wondering about just how much age is a factor?
    Age by itself is not a factor at all on steel. If you found a set of 85 year old wheels that were never used (and not rusted), they would still be brand new. Other materials are subject to deterioration by things like UV and humidity. It's the usage factor that matters on steel. In any event, you can dye-check the wheels for any evidence of cracking. If there are no cracks, and you plan to use them as designed, you can rely on them to be safe.
  22. Russco
    Russco
    from Central IL
    I had a wheel center fail on the Right Rear of a open wheel dirt car entering a turn at about 80 MPH. The next 5 seconds or so were very exciting I was told. I’d just ***ume that I never have that experience that again. Wheel fatigue and failure is nothing to joke about. This was a quality name brand alumin beadlock wheel too. That said I wouldn’t have a problem running a 40 Ford wheel at highway speeds or slightly above so long as it visually appeared to have no defects in it.
  23. I ve had steel rims crack at the bead because of metal fatuge. Ive seen semi truck frames that metal fatuged and cracked and couldn't be repaired by welding. It wasn't necessarily the age but the numberof miles driven. Now those Square Cab 73 up cheevy trucks the frames would break right at the steering sector. I think it was just brittle carbon steel. Old steel was better because it was made fron Raw ores. New steel is often made from recycled s**** and has many inpurities.
    warhorseracing and Boneyard51 like this.
  24. warhorseracing
    warhorseracing
    from cameron wv
    Old Jeeps were known for that too. I think that was more of a design engineering failure than materials but would require actual testing to determine the cause.
  25. Boneyard51
    Boneyard51
    Old Wolf you are right about recycled steel in new cars and trucks. While outfitting new trucks , sometimes it was necessary cut two inches off the rear of one ton frames. On one brand of truck, that I won’t mention fir fear of upsetting folks, when we were cutting we would hit hard spots that would wipe the teeth right off our port a band saw. They didn’t quite get some of those bearing in the junk steel 100% melted.
    Bones
  26. oldiron 440
    oldiron 440
    It seams like I'm herring more about axle flanges breaking on even non performance aplacations lately. I don't see anything wrong with having spindles and steering components Magnafluxed. Hell I've got history and these parts are older than me.
  27. ChevyIIman65
    ChevyIIman65
    Iron blocks (SEASON) with heat cycles and age they break in and settle so with engines your better off with a used one like 30 40 years virgin of course rather than a brand new cast
    Sent from my LG-LS777 using The H.A.M.B. mobile app
    nugget32 and Boneyard51 like this.
  28. alanp561
    alanp561
    I would worry about the wheel manufacturer. Running a jalopy cl*** car back in the late 60s and my helper put a stock Dodge rim on the right front of my Ford. Lug nuts pulled right through the wheel going into the first turn. Never had a Ford rim do that.
  29. Atwater Mike
    Atwater Mike
    ...And the cooking...
    Chili Phil likes this.
  30. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>Lug nuts pulled right through the wheel going into the first turn.>>>
    Of course. That's cuz the lug nuts & studs on a Dodge are usually much bigger than those used on a Ford. I thught everybody knew that. 8^) Jack E/NJ
