does this look like a decent start?
Discussion in 'The Hokey Ass Message Board' started by ChrisMicheals, Jan 14, 2009.
  1. ChrisMicheals
    ChrisMicheals
    home built frame with redone model A front axle, new tires in front, S10 rear axle chrome ladder bars hold it it with coils back there, slicks in rear, and a model A gas tank fit into the start of a homemade tub.
    i am going to start by making some gussets for the frame to strengthen it a little bit, and currently i am looking for a body to stick on the frame the t bucket would be cool, but it rains alot here and i'd like to drive to work on occasion
    ideas suggestions input it all helps. thanks guys
  2. parksquijada
    parksquijada
    from norcal
    absolutely! did someone else start this and you bought it. or did you start it a while ago. coilover rear w/ panhard bar? looks nice. no sbc? if you paint it it wont be a "traditional" rod.
  3. chaddilac
    chaddilac
    It may work, just depends on how you tackle the sheetmetal that's left to put on!
  4. I wouldn't trust that little tab of steel to hold the ladder bars on.
    At least from the picture it looks like it needs a little more support, and maybe more welding...I cant tell if its welded on the sides.
    It could be a cool project..just give it a good once-over.
  5. ChrisMicheals
    ChrisMicheals
    the tab of steel needs some gussets to support the ladder bars, i agree 100%
    i bought this thing for 400 bucks as it sits with a ton of parts included, the main thing is it needs alot of welding done, and will be done right. i am really wanting to find a different style body to put on it id realllly like a 3 window but i did a little work in paint. i came up with an idea of what she'll look like a little better
  6. ChrisMicheals
    ChrisMicheals
  7. 29nash
    29nash
    from colorado
    I could use a frame built like that. Looks solid. How is the front axle hung on, I can't tell.
  8. Only if ya got it FREE!!!
  9. Little Wing
    Little Wing
    from Northeast
    400 yeah,,seen far worse far WAY much more,,really depends on what you expect out of it
  10. Kustom7777
    Kustom7777
    from Austin, TX
    i dont think that tie down strap will hold the engine in,,:)
    seems like a good deal for $400....
  11. Unless I am seeing things, whoever told you that was a Model A front axle was blowing smoke. Car has potential, for sure.
  12. SapienKustom
    SapienKustom
    from Merced, CA
    You might be able to do something with that. I never really liked the way disc brakes look on a fenderless car, but thats just my opinion.
  13. kruzr
    kruzr
    Good start,a truck cab with short box would look nice.
  14. flynbrian48
    flynbrian48
    A buddy of mine here in Kalamazoo has built quite a few roadsters exactly this way, using an A or T cowl, and square tubing and sheet metal for the rest of the body. I can't say that they're pretty, but they're good 50 footers! I think they're a little to angular, but they do have a sort race car, functional look. This rendering is VERY similar to his cars.
  15. 29AV8
    29AV8
    looks like you have the right engine. go blue oval............
  16. 38plymouth
    38plymouth
    Please find a body to put on that. Then it'll be a good start. If you don't want to do that then use a small dumpster for the body, it'll save you a lot of work.:cool:
  17. Mr48chev
    He's right, that isn't a model A axle it looks to be parallel spring axle that is probably off a late 40's or early 50's pickup. I have seen a couple of them used with cross springs and have photos of one used with quarter epileptic springs that looks simple and easy to do.
    If you want a closed cab rig I think I would gather pieces to build a 28/29 closed cab pickup cab as you already have the gas tank top.
    Other than that it just looks like you have the usual scabs to clean up on the frame.
  18. southpark
    southpark
    mama said if you cant say anything nice dont say anything at all. so ill just be quite :)
  19. Might want to rethink this part of the plan. Otherwise-yup.
  20. temper_mental
    temper_mental
    from Texas
    Good luck with your build .My last 2 cents
  21. KreaturesCCaustin
    KreaturesCCaustin
    from Austin, TX
    You have a long road ahead of you, but for 400 bones, it's a decent start. 90% of it will be making the frame better looking and stronger. I've seen worse on "show" cars.
  22. 60srailjob
    60srailjob
    from nowhere
    long road ahead of you but I think it alright I would have bought it.....
  23. PollockzRodz
    PollockzRodz
    Wow for $400 you cant beat it. The steel for the frame is easily $170 around here. The rear end is already mounted but needs a little more fab work to make it safe but its a start. the frontend even though not a model A could be worth $100+ Just for a straight axle front end. The tub could easily be knocked out with some time and some tin and the motor I wouldnt use "Not a ford fan" but if I picked it up for $400 I would end up using that power plant haha. Good luck with your build for the price your gunna do just fine.
  24. missysdad1
    missysdad1
    I think this is a heck of a start of a nice entry-level low-buck modified. But, if you've not got a lot of experience ch***is building, you might want to find a mentor to help you out. Suspension geometry can be tricky for a beginner, but an "old hand" can help you avoid the more difficult pitfalls you'll encounter along the way.
    There's nothing wrong with asking for help. Regardless of what you may have heard, nobody is born an expert. We all had to learn...one way or the other.
    Good luck with your project! :)
  25. ChrisMicheals
    ChrisMicheals
    thanks guys for all the advice, if flyn would like to lend a hand it would be much appreciated, ive built a few 4x4's in my short life but want to try something harder
    i will dig into it later on this year and make sure to take lots of pictures, if need be i will redo the whole frame but it really appears to need more gussets, a few more braces and then it should be alright
  26. zman
    zman
    from Garner, NC
    I don't like the body frame being welded to the frame. I'd also go over every bit of work already done. How are you gonna ***le it? Looks like a homebuilt frame, a cowl, an an engine. Do we even know if the engine and rear are good?
  27. 29nash
    29nash
    from colorado
    Along the way as you get ready to finalize any changes to the suspension, mock it up and run it by here to get opinions on safety/strength/concept of mechanical application. As far as look goes do what you like. I like a top on a driver, a truck cab would be a cheap and dandy way to go.
  28. DE SOTO
    DE SOTO
    Looks like you paid $400.00 for a pair of Skinny Cragar wheels, An S/b Ford & trans, Pair of Slicks, Old Ladder Bars & Model A gas tank.
    The rest is S**** metal.
  29. ChrisMicheals
    ChrisMicheals
    well, not everyone has the luxury to live in California where it rarely rains and cars have zero rust. i work with what i can get and i dont have any intention of not going over everything 100% and practically rebuilding the whole thing.
  30. 38plymouth
    38plymouth
    I admire your enthusiasm but you really don't know what you're in for. Anyway, it's all in the fun of keeping busy and being creative. Probably after about a month or two when the reality of it sets in, you will have found another "good start" and can make something from the two. Have fun.....
