Does this look safe at all??
Discussion in 'The Hokey Ass Message Board' started by gasser52, Aug 11, 2007.
  1. gasser52
    gasser52
    Nothing personal to the guy who did the work on this but he was telling me about his work and how hes going to be helping out build cars for some of the guys in a well known car club. But if you look at the picture of this step notch nothing is boxed or even straight. I sure wouldnt want this guy building anyone a car that is going to fall apart on the freeway and hurt someone!
    http://viewmorepics.myspace.com/ind...endID=1438997&albumID=681897&imageID=11556356
  2. LiL'buddha
    LiL'buddha
    wow thats so dangerous i love his half cut leaf spring to
  3. squirrel
    " You Must Be Logged-In to do That!"
    no can see no pictures
  4. gasser52
    gasser52
    Look at the part he welded onto the frame is just bent up by a hammer where he didnt cut it all the way or something. He told me he cut the peices out using about 50 grinding discs.
  5. 52 HenryJ
    52 HenryJ
    looks like its pretty unsafe to me
  6. Kickstarter
    Kickstarter
    from NC
    Turn the TV off.
  7. luckys8ba
    luckys8ba
  8. ss34coupe
    ss34coupe
  9. OLDSKEWL61
    OLDSKEWL61
    rockabilly poser strikes again!
  10. kustomfordman
    kustomfordman
    Wow, can I get his number, maybe he can build me a chassis cheap. That looks great, no gussets, no plating, just a...something on the bottom with a...something bent up. Nice piece of work. I hope it's not supporting anything like the car.
  11. jeffrob
    jeffrob
    graduate of the erecter set engineering school.........
  12. Yeah, it's perfectly safe. As long as the car is only going to sit on display in front of a retro McDonalds. With a couple jackstands under it.
  13. SHIPFITTER1955
    SHIPFITTER1955
    from wyo
    if you want safe go check out the OSHA message board.....bunch of sissies......
  14. Degreaser
    Degreaser
    Awesome welds.
  15. Ebert
    Ebert
    from Keller, TX
    Yikes is right...some guys can defend these kind of guys all they want, but this kind of half-ass crap could hurt somebody!
  16. INXS
    INXS
    well,
    on the bright side at least he sprayed some black paint on the notch...
  17. gravity wins every time!
  18. crapshoot
    crapshoot
    kinda a crappy attitude for an FNG
    I don't think those are welds it looks like bubble gum painted over
  19. ray
    ray
    from colorado
    what the hell does he think he need a 18" notch for? ain't no tire gonna tuck the axle up that high unless he cuts hole in his quarter panels for the tires to stick up through.
  20. HotRodHeb
    HotRodHeb
    The funniest part is the caption that he wrote for the picture....
    "Overkill"
  21. 52 HenryJ
    52 HenryJ
    the POS in question!!!!!!!!
  22. roddinron
    roddinron
    It ain't just him out on that highway, and I'll bet your tune would change if he killed or injured someone you cared about. And if he does, his reckless behavior could effect all of us.
    A persons craftsmanship speaks volumes about that person, what does shitty work like that say about him?
  23. Salty
    Salty
    from Florida
    Where's this ass hat from so I can avoid that particular state....
  24. Safe, safe at second base! But he will never make it to home base.
  25. Well,if you welded like that as a "Shipfitter",you would sink!!! FNG's that just post smartass comments,don't usually last very long here.Unsafe crap might be OK in your eyes,but rodding in general gets a bad rap if unsafe building kills or injures anyone.If you can't contribute anything worthwhile maybe you should just read and learn for a while.Try engaging your brain,before engaging your mouth!!!:eek:
  26. lowdowncustom
    lowdowncustom
    from austin tx
    thats about as safe as raping a porcupine....
  27. ...after you turn it inside out.
  28. SchlottyD
    SchlottyD
    UUUHHHHHHHHH>>>>>>>>>>>= WHY?! Jeez, the car only has 15's, why not just do some research and do it right the first time? I know I'm scared to death doing my frame right now, that's why I'm taking my time with research, lots of measurements and prep, right now it's cut and stepped but figuring out how much to overlap for weld area and the safest way to box and gusset it before I go back together with it. I know I don't want to die or kill someone else because I got in a hurry or did something wrong.
  29. SlowandLow63
    SlowandLow63
    from Central NJ
    Look what Jesse James did to unknowing skateboarders. Probably failed geometry class too.
