Technical Does this sound like a bad turn signal switch?
Discussion in 'Traditional Hot Rods' started by hillbilly4008, Mar 9, 2014.
  1. hillbilly4008
    hillbilly4008
    from Rome NY
    I just got through totally re-wiring my car and have an issue with my turn signals. I can get the signal lights all to light up, but not flash. I have all new flashers and have power going through them.(both signals and hazard)
    With the hazard ****on pushed it does nothing at all.
    I also am not getting the brake lights to light with the pedal, but I haven't checked to see if the brake switch is bad yet(doubtful) but the brakes are fedd through the signal switch.
    I'm stumped. It's not a ground issue, all new wires and connections. The only thing old is the steering column.
  2. tfeverfred
    tfeverfred
    Wired up wrong.
  3. hillbilly4008
    hillbilly4008
    from Rome NY
  4. Engine man
    Engine man
    from Wisconsin
    If you remove the flasher do the lights still light up? If you put a jumper wire in place of the 4 way flasher, do the lights light up when you turn the 4 ways on? The turn signal flasher should be a lighter duty because it only draws power from 2 bulbs at a time. Electronic flashers will work with almost any number of bulbs. We would need to know more about the vehicle, steering column/turn signal switch and wiring harness.
