Does this sound like a dead Ign. Module?
Discussion in 'The Hokey Ass Message Board' started by Von Rigg Fink, Aug 22, 2011.
  1. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Im running an SBC with a Pertronix Flamethrower HEI small cap distributor on my Hot Rod
    Havent gotten many miles on it since getting it on the road, when this problem came up.
    It will start up..run a bit and shut down as if you turned off the key.
    sometimes it will run longer than other times, sometimes it a matter of moments and it shuts off. sometimes it just cranks and wont fire right off.
    Coil is new and has internal resitor, Pertronix age unknown.
    whats the best way to test for a dead or soon to be completely dead Module?
    thanks all:cool:
  2. 32v
    32v
    from v.i.
    try another coil
    if you used pertronics coil they have a high failiar rate
    wayne
  3. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Sorry i should have said no pertronix coil its an accel ..but i guess it could be junk too
    I also thought it could be a hot coil problem, if a Module goes bad are they bad , done..or could they play games like this too?
  4. squirrel
    put points in it, see how it works?
  5. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I might try that if i find it is in fact dead
    I found a write up just now on how to test it with my volt meter and a lighted test probe
  6. squirrel
    You might see if it's getting power just after it dies, use a volt meter or test light. Intermittents are fun to figure out....
  7. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I just found a write up on how to test like your saying as you were typing..
    I'll give that a try
    it is intermittent..big time
    sometimes it shuts off while its running but so quickly it fires back up before the engine stops rotating..than other times it stops dead
    My tac bounces big time when that happens ..it goes to 0..than back up to where ever the throttle is set..like if im at 2200RPM..it quits drops to 0 like a rock..than sometimes back up to throttle setting
  8. Buick59
    Buick59
    from in a house
    Use a GM module. I've had bad luck with aftermarket modules.
    My experience with them is, they either work or die. No in between, just dead or alive.
  9. squirrel
    Could be a loose wire or bad ignition switch.
  10. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Yeah ,,could be..this **** is a drag to find sometimes
    guess i got my work cut out for me this week
  11. Von, does the primary resistance of the coil{ w/built n ballast} match the module of the distributor?
  12. Von Rigg Fink
    Von Rigg Fink
    from Garage
    according to them it does
    so, yes
    I did ask before buying it
    and it did fine for quite a while until just recently
  13. 283john
    283john
    When mine die, they have never came back
  14. Special Ed
    Special Ed
    HotRodDon on here works for Pertronix. I'm certain he can walk you through any issues. He knows his stuff...
  15. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Yeah , Im hearing that from others too..Im thinking its the coil..I call it the old Hot coil problem..and its acting like that.
    although like squirrel said it could be these **** ignition switches too..
    gotta do some electrical trouble shooting this week
    Joy, my favorite:rolleyes:
  16. Von Rigg Fink
    Von Rigg Fink
    from Garage
    thanks Ed
    I shot him a PM early this morning, before the thread..he might chime in
  17. brad chevy
    brad chevy
    Really sounds more like a wiring issue since its firing right back up before it shuts down completely. Pertronics is either dead or alive,no inbetween. Like suggested check connections and ignition switch wiring pigtail.
  18. djust
    djust
    from Oklahoma
    GMC Bubba set mine up and when I thought the module died because I left the ignition switch on while the car was not running it cooked the coil.
    Even though it was my fault he offered to replace the module if it was bad, but the module was fine.
    He's seems like a really good guy.
    He could probably walk you through some of the troubleshooting.
  19. Easy to eliminate the wiring and ignition switch from the system. Can you easily run a jumper wire from the battery + to the Pos side of the coil and test drive? How about your grounds , have you checked them? Pertronix modules either work or they don't. TR
  20. Von Rigg Fink
    Von Rigg Fink
    from Garage
    :eek: i might have done the same thing while building this car:eek:
  21. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Great Idea TR..I'll give that a try, thats how i was bench running the engine so , It should be a good way to rule out the switch and the harness.
    I have grounds up the wazoo
    sounds like the general idea is , the Mods. either are good or bad , no in between, so tonight i will run a jumper and see what gives
  22. 32v
    32v
    from v.i.
    the module works or dont work like i said try another coil . it will take 2 minutes to switch it out
  23. Von Rigg Fink
    Von Rigg Fink
    from Garage
    yep, I gotcha
    Im going to try rule out the Ign switch..than the coil
    My coil isnt a 2 min job on this car..its up inside my dash..
    I hate looking at coils on firewalls..im funny that way
    probably because i hid it, that will be the culprit:mad:
  24. Good deal Von, just remember some freek occurance like the throttle sticking, and you have to yank off the wire, shutting the key off wont help:eek:
  25. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Good point ,Boss;)
  26. 40 & 61 Fords
    40 & 61 Fords
    My Dad and I have both had modules go out on new Mallory uni-lites.
    His acted just like what you are describing. It would run until it got hot, then die. Usually it ran about a couple of minutes after the engine had cooled down. Mine on the otherhand just flat died. I tried a coil, and checked the switch, and a few other things. Finally, a buddy had a points distributor that we KNEW was good. Popped that in, and BINGO the car ran just fine. Pisser about both these module failers were that the distributors both had less than a couple hundred miles on them when they failed, so we didn't START there, because "they're new, and couldn't possibly be the problem!"
  27. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Thanks man
    Im planning on testing mine before i go too far..I figure its the easiest (in my set up) to trouble shoot..if it comes up good , than I'll dig deeper
  28. Sheep Dip
    Sheep Dip
    from Central Ca
    Coil...had the same issue with a brand new coil...worked fine until it got warmed up a bit, changed the coil and trouble free since.
  29. reekie6
    reekie6
    I guess my first step would be to see if you lost spark. you did not list if you ever checked that. could be a fuel problem???
  30. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I aint tested nothin yet..just surfin for clues, happened just the other day
